주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z1 Compact Motherboard Replacement
필요한 것
  1. Sony Xperia Z1 Compact Motherboard Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Heat along the edges of the back cover using a heat gun to soften the glue.
    댓글 쓰기
  2. Sony Xperia Z1 Compact Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
    댓글 쓰기
  3. Sony Xperia Z1 Compact Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
    댓글 쓰기
  4. Sony Xperia Z1 Compact Motherboard Replacement, Battery: 4 단계, 이미지 2개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
    댓글 쓰기
  5. Sony Xperia Z1 Compact Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
    댓글 쓰기
  6. Sony Xperia Z1 Compact Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
    댓글 쓰기
  7. Sony Xperia Z1 Compact Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the battery from the device
    댓글 쓰기
  8. Sony Xperia Z1 Compact Motherboard Replacement, External Speaker: 8 단계, 이미지 2개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement, External Speaker: 8 단계, 이미지 2개 중 2개
    • Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
    댓글 쓰기
  9. Sony Xperia Z1 Compact Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Sony Xperia Z1 Compact Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Wedge the plastic opening tool under the back frame. Move the plastic opening tool around the entire frame to separate it from the adhesive.
    댓글 쓰기
  10. Sony Xperia Z1 Compact Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the back frame.
    댓글 쓰기
  11. Sony Xperia Z1 Compact Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
    댓글 쓰기
  12. Sony Xperia Z1 Compact Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the external speaker.
    댓글 쓰기
  13. Sony Xperia Z1 Compact Motherboard Replacement, Motherboard: 13 단계, 이미지 2개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement, Motherboard: 13 단계, 이미지 2개 중 2개
    • Remove the square rubber gasket from the camera using the plastic spudger.
    댓글 쓰기
  14. Sony Xperia Z1 Compact Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the black plastic corner still holding in the motherboard.
    댓글 쓰기
  15. Sony Xperia Z1 Compact Motherboard Replacement: 15 단계, 이미지 3개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement: 15 단계, 이미지 3개 중 2개 Sony Xperia Z1 Compact Motherboard Replacement: 15 단계, 이미지 3개 중 3개
    • Carefully pry up on the four sides of the motherboard using the plastic spudger til it separates from the base of the phone.
    댓글 쓰기
  16. Sony Xperia Z1 Compact Motherboard Replacement: 16 단계, 이미지 3개 중 1개 Sony Xperia Z1 Compact Motherboard Replacement: 16 단계, 이미지 3개 중 2개 Sony Xperia Z1 Compact Motherboard Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the motherboard from the device.
    • There may be a small yellow adhesive underneath the motherboard still holding it in. Slide the tip of the spudger through it to sever it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Daniel Benjamin
회원 가입일: 09/21/17
261 평판
안내서 1개를 작성함
Washington State, Team S4-G1, Phelps-Hillen Fall 2017 Washington State, Team S4-G1, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S4G1
6 회원들
안내서 16개를 작성함
1가이드 댓글
hi
Recently i brought Xperia Z1 now i am facing charging problem.
i already change new to battery but it is charging 75 % only.
after charging 75% my phone screen continually on and off
please let me know how can i fix this problem.
malinduariyasingha - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 36
전체 시간: 4,163
