주요 콘텐츠로 건너뛰기
Sony Xperia Z5 Rear Camera Replacement
필요한 것
  1. Sony Xperia Z5 Rear Camera Replacement, Back Cover: 1 단계, 이미지 1/1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the edges on the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Sony Xperia Z5 Rear Camera Replacement: 2 단계, 이미지 1/2 Sony Xperia Z5 Rear Camera Replacement: 2 단계, 이미지 2/2
    • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
    • Pull up the suction handle to generate a gap.
    • Insert an opening pick into the gap to further separate the rear glass from the phone assembly.
    • The adhesive of the Xperia Z5 is fairly weak and it is possible to remove the rear glass without the use of an opening pick. In case you‘re having trouble you can have a peek at the opening procedure of the Xperia Z4.
  3. Sony Xperia Z5 Rear Camera Replacement: 3 단계, 이미지 1/2 Sony Xperia Z5 Rear Camera Replacement: 3 단계, 이미지 2/2
    • Carefully lift and remove the rear glass.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  4. Sony Xperia Z5 Rear Camera Replacement, Battery Disconnect: 4 단계, 이미지 1/2 Sony Xperia Z5 Rear Camera Replacement, Battery Disconnect: 4 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the battery flex cable.
  5. Sony Xperia Z5 Rear Camera Replacement, Rear Camera: 5 단계, 이미지 1/2 Sony Xperia Z5 Rear Camera Replacement, Rear Camera: 5 단계, 이미지 2/2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  6. Sony Xperia Z5 Rear Camera Replacement: 6 단계, 이미지 1/3 Sony Xperia Z5 Rear Camera Replacement: 6 단계, 이미지 2/3 Sony Xperia Z5 Rear Camera Replacement: 6 단계, 이미지 3/3
    • Remove the rear camera with a pair of tweezers.
    • Compare your new replacement part to the original part — you may need to transfer a rubber gasket to your new part before installing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,449 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,820개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 513
