주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia ZL Battery Replacement
필요한 것
  1. Sony Xperia ZL Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the phone face down.
    댓글 쓰기
  2. Sony Xperia ZL Battery Replacement: 2 단계, 이미지 1개 중 1개
    • At the bottom of the phone will be a cover that flips open. A sticker will be under and when the sticker is peeled back, two screws will be revealed. Use a JIS J00 screw head to unscrew.
    댓글 쓰기
  3. Sony Xperia ZL Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Once the two screws have been removed. Take the prying tool to pry off the back cover of the phone. Next take a JIS J00 screwhead and unscrew the 5 screws that are located in the photo.
    댓글 쓰기
  4. Sony Xperia ZL Battery Replacement: 4 단계, 이미지 1개 중 1개
    • After the screws have been taken out, carefully disconnect the 7 indicated connectors using a small plastic opening tool or spudger.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    댓글 쓰기
  5. Sony Xperia ZL Battery Replacement: 5 단계, 이미지 1개 중 1개
    • The last connector is located under the black sticker. Peel back the black sticker and disconnect the last connector.
    댓글 쓰기
  6. Sony Xperia ZL Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Once all the connectors have been disconnected. You will want to use a small prying tool to pry out the back camera and all its components from the phone.
    댓글 쓰기
  7. Sony Xperia ZL Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the electrical panel with a plastic opening tool.
    댓글 쓰기
  8. Sony Xperia ZL Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Take a small plastic prying tool and pry out the battery of the phone. The battery has adhesive tape that connects it to the phone which makes it difficult to pry out. Make sure to try prying from different angles of the battery.
    • Use a plastic prying tool when taking out the battery because any puncture within the battery could cause a fire.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Liam Kanaley
회원 가입일: 11/03/15
433 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 UMass Dartmouth, Team 1-7, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G7
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 35
전체 시간: 2,105
