주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia ZL Volume and Power Button Replacement
필요한 것
  1. Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: 1 단계, 이미지 2개 중 1개 Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: 1 단계, 이미지 2개 중 2개
    • Open the small cover on the bottom of the rear cover.
    • Peel back the sticker under the cover to reveal two screws.
    • Remove the two JIS #00 screws from the back of the phone.
    댓글 쓰기
  2. Sony Xperia ZL Volume and Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the six screws from the phone using a JIS #00 screwdriver.
    댓글 쓰기
  3. Sony Xperia ZL Volume and Power Button Replacement: 3 단계, 이미지 1개 중 1개
    • Use a nylon spudger to disconnect the seven connectors.
    • Never use a metal spudger around the battery. Use plastic or nylon prying tools instead.
    댓글 쓰기
  4. Sony Xperia ZL Volume and Power Button Replacement: 4 단계, 이미지 1개 중 1개
    • The last connector is located under the back sticker.
    • Peel the sticker back to get access of the connector and use a nylon spudger to disconnect it.
    댓글 쓰기
  5. Sony Xperia ZL Volume and Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the camera assembly using an opening tool or spudger.
    댓글 쓰기
  6. Sony Xperia ZL Volume and Power Button Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the motherboard with an opening tool or spudger.
    댓글 쓰기
  7. Sony Xperia ZL Volume and Power Button Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the battery with a plastic opening tool or spudger.
    • The battery has adhesive tape that connects it to the phone which makes it difficult to pry out.
    • Never use metal prying tools on the battery. Be sure to use a plastic prying tool to avoid puncturing the battery.
    댓글 쓰기
  8. Sony Xperia ZL Volume and Power Button Replacement: 8 단계, 이미지 1개 중 1개
    • Detach the plastic covering from the top side of the phone by hand.
    댓글 쓰기
  9. Sony Xperia ZL Volume and Power Button Replacement: 9 단계, 이미지 1개 중 1개
    • Pry off the signal receptor and front camera using an opening tool or spudger.
    • The signal receptor has adhesive tape underneath so proceed with caution when prying.
    댓글 쓰기
  10. Sony Xperia ZL Volume and Power Button Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the volume and power button with an opening tool or spudger.
    • For replacement, this component comes as a whole. If the volume and power button do not work, they will need to be replaced together.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Liam Kanaley
회원 가입일: 11/03/15
433 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 UMass Dartmouth, Team 1-7, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G7
3 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 20
전체 시간: 2,444
