주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SoundBot SB571 Battery Replacement
필요한 것
    1. SoundBot SB571 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Before disassembling the speaker, make sure it is powered off.
      • Place the speaker on a flat surface.
      • Take your blue plastic opening tool and remove the outside cover.
      댓글 쓰기
    2. SoundBot SB571 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Reorient the speaker so the black panel is facing up.
      • Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
      • Now remove the plate.
      댓글 쓰기
    3. SoundBot SB571 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Reorient the speaker so the bottom is facing up.
      • Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
      • Now open the plate.
      댓글 쓰기
    4. SoundBot SB571 Battery Replacement: 4 단계, 이미지 2개 중 1개 SoundBot SB571 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
      댓글 쓰기
    5. SoundBot SB571 Battery Replacement: 5 단계, 이미지 2개 중 1개 SoundBot SB571 Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Disconnect the battery wires from the circuit board.
      댓글 쓰기
    6. SoundBot SB571 Battery Replacement: 6 단계, 이미지 3개 중 1개 SoundBot SB571 Battery Replacement: 6 단계, 이미지 3개 중 2개 SoundBot SB571 Battery Replacement: 6 단계, 이미지 3개 중 3개
      • Reorient the speaker so the back side is facing up.
      • Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
      • Loop the battery wires through the opening in the back plate.
      • The battery and it's connective wires have been completely removed from the speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Yana
회원 가입일: 02/09/16
672 평판
안내서 2개를 작성함
USF Tampa, Team 2-50, Cagle Spring 2016 USF Tampa, Team 2-50, Cagle Spring 2016 회원
USFT-CAGLE-S16S2G50
4 회원들
안내서 4개를 작성함
9가이드 댓글
Please provide the source to buy the replacement battery
Madhu Mohan Bhukya - 답글 공유
Sir ,m n jully m flipcart se soundbot buy tha jisme kuch dikat aa rhi h bettery ki bajah se
Raj Saini - 답글 공유
They don't sell batteries!!
international.loop - 답글 공유
It says above that battery not for sale.
A simple online search and you will find the battery.
Mark Friend - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 40
전체 시간: 9,611
