주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sprout Channel Cubby Battery Replacement
필요한 것
  1. Sprout Channel Cubby Battery Replacement, Dissasemble the device: 1 단계, 이미지 2개 중 1개 Sprout Channel Cubby Battery Replacement, Dissasemble the device: 1 단계, 이미지 2개 중 2개
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
    댓글 쓰기
  2. Sprout Channel Cubby Battery Replacement, Battery: 2 단계, 이미지 2개 중 1개 Sprout Channel Cubby Battery Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Remove the black electrical tape over the ribbon connector.
    • Remove the ribbon connector over the battery.
    • Make sure to be careful of the ribbon connector while working on the device.
    댓글 쓰기
  3. Sprout Channel Cubby Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Next you must heat up the battery to help weaken the adhesive connecting the battery to the device.
    댓글 쓰기
  4. Sprout Channel Cubby Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Once this is done start to pry the battery away from the device carefully. It helps to start at the corners and move inward.
    댓글 쓰기
  5. Sprout Channel Cubby Battery Replacement: 5 단계, 이미지 2개 중 1개 Sprout Channel Cubby Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Once you remove the battery from the device it is still connected by three wires: red, black, and, white. It is important to remember the order they are in when reconnecting the new battery.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
jasen biggins
회원 가입일: 08/26/15
741 평판
안내서 5개를 작성함
USF Tampa, Team 14-101, Meier Fall 2015 USF Tampa, Team 14-101, Meier Fall 2015 회원
USFT-MEIER-F15S14G101
4 회원들
안내서 12개를 작성함
7가이드 댓글
Ours is only 6 months old. It only works when it stays plugged in. Battery is bad?
Rachel - 답글 공유
I had the same problem, only played while plugged in and would not charge.. I found that the battery wires while appearing tight one wire had broken inside the wire insulation at the solder pad on the main board. When I redid the connection it charges, and works well. 8/11/16
larrywb135 - 답글 공유
My grand daughters won't come on, should I take it to an electronic store?. I don't want to try and pry it open, for fear I may make it worse, she loves her tablet, and it is very helpful for her with school, she's had it 2 years and I put it away for about 8 month, for going on line, without permission, I gave it back in Sept. Now its not charging or coming on. Thank you.Deborah
jacksondebo2010 - 답글 공유
Where can I get a battery?
crzyinind - 답글 공유
You can get one at Amazon, EBay and more.
Liu Woods - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 42
전체 시간: 4,208
