주요 콘텐츠로 건너뛰기
Spy Net Ultra Vision Goggles Infrared Lights Replacement
필요한 것
  1. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Device: 1 단계, 이미지 1개 중 1개
    • Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pry open the shell using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
  2. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: 2 단계, 이미지 3개 중 1개 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: 2 단계, 이미지 3개 중 2개 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: 2 단계, 이미지 3개 중 3개
    • Find the infrared light assemblies, which are located at the front end of the device on either side of the lens.
    • The process is the same regardless of which light you are replacing.
    • Lift the light assembly away from the rest of the device.
  3. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Light Assembly: 3 단계, 이미지 1개 중 1개
    • Use the plastic opening tools to pry open the light assembly.
  4. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Disconnect the Lights: 4 단계, 이미지 1개 중 1개
    • Use the soldering iron and desoldering braid to de-solder the wires from the lights.
    • Check out This Guide for tips on soldering and de-soldering connections.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Travis Kempf
회원 가입일: 09/22/14
198 평판
안내서 1개를 작성함
USF Tampa, Team 4-5, Brown Fall 2014 USF Tampa, Team 4-5, Brown Fall 2014 회원
USFT-BROWN-F14S4G5
3 회원들
안내서 6개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 1,066
