주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Stabilizer Spring Replacement
필요한 것
  1. Stabilizer Spring Replacement, Opening The Case: 1 단계, 이미지 1개 중 1개
    • Push the gray tab down, using a spudger if necessary, and the battery will come out.
    • Failure to remove the battery prior to disassembly can result in harm.
    댓글 쓰기
  2. Stabilizer Spring Replacement: 2 단계, 이미지 3개 중 1개 Stabilizer Spring Replacement: 2 단계, 이미지 3개 중 2개 Stabilizer Spring Replacement: 2 단계, 이미지 3개 중 3개
    • There are a total of six screws that must be removed using the the #000 Philips screwdriver.
    • As per picture one: there is one 4.9 mm Philips head screw on the left side of the camera.
    • As per picture two: on the bottom of the camera, there are three 3.4 mm Philips head screws; these are located on the darker area of the case.
    • As per picture three: there are two 5.3 mm Philips head screws on the right side, one is beneath the USB cover.
    댓글 쓰기
  3. Stabilizer Spring Replacement: 3 단계, 이미지 1개 중 1개
    • Open the case by peeling off the back panel.
    • Pull the case apart gently so that the ribbon connector will not tear.
    댓글 쓰기
  4. Stabilizer Spring Replacement: 4 단계, 이미지 2개 중 1개 Stabilizer Spring Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the two ribbon cables as shown in picture one.
    • Avoid using metal pry tools, as shown in the photo, on internal electronic components, as it can cause a short and damage the device. Use an ESD-safe tool such as a standard nylon spudger.
    • To disconnect a ribbon cable, use a spudger to lift the black tab then pull the ribbon out. This works the same for all ribbon cables.
    댓글 쓰기
  5. Stabilizer Spring Replacement: 5 단계, 이미지 1개 중 1개
    • The back panel has now been removed.
    댓글 쓰기
  6. Stabilizer Spring Replacement, Sensor Assembly: 6 단계, 이미지 3개 중 1개 Stabilizer Spring Replacement, Sensor Assembly: 6 단계, 이미지 3개 중 2개 Stabilizer Spring Replacement, Sensor Assembly: 6 단계, 이미지 3개 중 3개
    • Using a spudger, remove the ribbon cables by pushing the black tab back and gently pulling the cable out.
    • Do this process for the two ribbon cables shown in the third photo.
    댓글 쓰기
  7. Stabilizer Spring Replacement: 7 단계, 이미지 2개 중 1개 Stabilizer Spring Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the #000 Phillips screwdriver, remove the 4.3 mm screw as shown by the screwdriver and the 6.0 mm screw holding down the ribbon.
    • These screws have washers on them, do not to lose them.
    • Using tweezers, gently lift the ribbon off the sticky pad.
    댓글 쓰기
  8. Stabilizer Spring Replacement: 8 단계, 이미지 3개 중 1개 Stabilizer Spring Replacement: 8 단계, 이미지 3개 중 2개 Stabilizer Spring Replacement: 8 단계, 이미지 3개 중 3개
    • Unlike previous connectors, this cable has a light grey clip holding it in place on opposite side of the connector in regards where the ribbon is inserted. Flip it up and then using your fingers, gently pull the top ribbon cable out.
    댓글 쓰기
  9. Stabilizer Spring Replacement: 9 단계, 이미지 1개 중 1개
    • Using a #000 Phillips screwdriver, remove the 6.0 mm screw on the bottom left hand corner. You can locate the screw on the picture as the green circle.
    댓글 쓰기
  10. Stabilizer Spring Replacement: 10 단계, 이미지 2개 중 1개 Stabilizer Spring Replacement: 10 단계, 이미지 2개 중 2개
    • In the upper left hand corner, use the #000 Phillips screwdriver to remove the 6.0 mm screw.
    • Retain the copper washer held in by this screw.
    • Using tweezers gently lift the copper grounding strip.
    • Do not tear the strip as you pull it off, it must stay attached to the main camera body.
    댓글 쓰기
  11. Stabilizer Spring Replacement: 11 단계, 이미지 3개 중 1개 Stabilizer Spring Replacement: 11 단계, 이미지 3개 중 2개 Stabilizer Spring Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the bracket in the lower right hand corner. In order to do so, you must remove two different screws.
    • Using the #000 Phillips screwdriver, remove the 2.4 mm screw on the bottom.
    • Using the #000 Phillips screwdriver, remove the 6.0 mm screw on the top and lift off the bracket.
    댓글 쓰기
  12. Stabilizer Spring Replacement: 12 단계, 이미지 3개 중 1개 Stabilizer Spring Replacement: 12 단계, 이미지 3개 중 2개 Stabilizer Spring Replacement: 12 단계, 이미지 3개 중 3개
    • Now you can lift out the sensor assembly. The following steps will explain how to lift it out.
    • First, sightly lift the bottom half following the direction of the arrow.
    • Second, lift the top left up side up. It may be a little stuck so you will have to wiggle it out.
    • Finally, pull the entire assembly towards the bottom and away from the case.
    • There is a ribbon connector that is beneath the assembly. Be careful when lifting the assembly out. Do not yank it out very hard or you may damage the ribbon connector.
    댓글 쓰기
  13. Stabilizer Spring Replacement: 13 단계, 이미지 3개 중 1개 Stabilizer Spring Replacement: 13 단계, 이미지 3개 중 2개 Stabilizer Spring Replacement: 13 단계, 이미지 3개 중 3개
    • This is the sensor assembly with the photo showing the connected ribbon cable.
    • There are three washers held in by the 6.0 mm screws as shown in picture two. Be sure to replace them when reassembling.
    댓글 쓰기
  14. Stabilizer Spring Replacement: 14 단계, 이미지 1개 중 1개
    • The sensor assembly has been removed.
    댓글 쓰기
  15. Stabilizer Spring Replacement, Stablizer Spring: 15 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers grasp the end opposite the screw, pull against the tension and twist the spring out. You may have to try it a couple times, but just keep twisting and pulling at the spring.
    댓글 쓰기
  16. Stabilizer Spring Replacement: 16 단계, 이미지 1개 중 1개
    • When you pull the spring off one side, it will easily come off the other side. Just slide the spring off.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jeffery Smith
회원 가입일: 03/11/15
831 평판
안내서 6개를 작성함
Colorado Springs, Team 9-1, Panko Spring 2015 Colorado Springs, Team 9-1, Panko Spring 2015 회원
UCCS-PANKO-S15S9G1
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 68
전체 시간: 5,039
