주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Stapler Maintenance
    1. Stapler Maintenance, Open & Identify: 1 단계, 이미지 2개 중 1개 Stapler Maintenance, Open & Identify: 1 단계, 이미지 2개 중 2개
      • Be careful while handling staples or any sharp object in general.
      • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
      • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
      댓글 쓰기
    2. Stapler Maintenance, Insert Staples: 2 단계, 이미지 2개 중 1개 Stapler Maintenance, Insert Staples: 2 단계, 이미지 2개 중 2개
      • Get a cluster of staples and carefully place it in the carrier.
      • Make sure there is enough room for the pusher to contact the staples.
      • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
      댓글 쓰기
    3. Stapler Maintenance: 3 단계, 이미지 1개 중 1개
      • Don’t staple your hand, or anyone else for that matter.
      • Congratulations! You have successfully replaced staples in your stapler.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sequoia Equities
회원 가입일: 01/22/15
279 평판
안내서 1개를 작성함
2가이드 댓글
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - 답글 공유
@ cookie clicker When I attempted to load the staples, the spring became detached. However, I'm unsure where to reattach it, and I now have a loose, short plastic rod.
Nadia Eira - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 107
지난 7일: 628
지난 30일: 2,693
전체 시간: 58,701
