주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Staples 34462 Electric Pencil Sharpener Cutter Replacement
필요한 것
    1. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cover: 1 단계, 이미지 1개 중 1개
      • Pull out the shavings tray from the pencil sharpener.
      • Beware of loose pencil shavings falling on your workspace.
      댓글 쓰기
    2. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 2 단계, 이미지 1개 중 1개
      • Turn the pencil sharpener on its side.
      댓글 쓰기
    3. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 3 단계, 이미지 1개 중 1개
      • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
      • Using the plastic opening tool, remove the back plastic feet.
      • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
      • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
      댓글 쓰기
    4. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully pull apart the bottom panel from the top panel.
      • Be careful not to pull too forcefully as the panels are connected by wires.
      • Beware of pencil shavings falling out onto your workspace.
      댓글 쓰기
    5. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 5 단계, 이미지 1개 중 1개
      • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
      댓글 쓰기
    6. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 6 단계, 이미지 1개 중 1개
      • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
      댓글 쓰기
    7. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 7 단계, 이미지 1개 중 1개
      • Carefully pull the cover from the top panel and set it aside.
      댓글 쓰기
    1. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cutter: 8 단계, 이미지 1개 중 1개
      • Orient the top panel so that the sensor bracket is facing you.
      • Using a Phillips00 screwdriver, remove four 10.42mm screws.
      • Using a Phillips00 screwdriver, remove two 6.96mm screws.
      댓글 쓰기
    2. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 9 단계, 이미지 1개 중 1개
      • Pull out the outside cover to remove it from the cutter chamber and set them side by side.
      댓글 쓰기
    3. Staples 34462 Electric Pencil Sharpener Cutter Replacement: 10 단계, 이미지 1개 중 1개
      • Carefully pull the cutter out of the cutter chamber.
      • Beware of pencil shavings and debris.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jen Hawkins
회원 가입일: 10/27/14
470 평판
안내서 4개를 작성함
4가이드 댓글
Very clear, easy to follow. Nice photos.
uccbill - 답글 공유
where can I get a replacement cutter?
Mel Buchanan - 답글 공유
Did you find replacement blades?
Horace M Hargroves - 답글 공유
Absolutely great directions. However I lost the two 10.3mm screws somewhere along the line - I did not go any further at that point. I will check out replacement cutters and see if I want to pursue or purchase new. I believe this was my work stapler of the 80's.
Leslie H - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 39
전체 시간: 3,421
