주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SteelSeries Nimbus+ Controller Battery Replacement
필요한 것
  1. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: 1 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Controller Battery  Replacement, Remove the phone mount: 1 단계, 이미지 2개 중 2개
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    댓글 쓰기
  2. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the sticker: 2 단계, 이미지 1개 중 1개
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    댓글 쓰기
  3. SteelSeries Nimbus+ Controller Battery  Replacement, Unscrew the back cover: 3 단계, 이미지 1개 중 1개
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    댓글 쓰기
  4. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 4 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 4 단계, 이미지 2개 중 2개
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    댓글 쓰기
  5. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 5 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 5 단계, 이미지 2개 중 2개
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    댓글 쓰기
  6. SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Controller Battery  Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 2개
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    댓글 쓰기
  7. SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 7 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Controller Battery  Replacement, Release the plastic clips: 7 단계, 이미지 2개 중 2개
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    댓글 쓰기
  8. SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: 8 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: 8 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Controller Battery  Replacement, Unfold the back cover assembly: 8 단계, 이미지 3개 중 3개
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    댓글 쓰기
  9. SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: 9 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: 9 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Controller Battery  Replacement, Disconnect the battery cable: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    댓글 쓰기
  10. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the back cover assembly: 10 단계, 이미지 1개 중 1개
    • Remove the back cover assembly.
    댓글 쓰기
  11. SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: 11 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Controller Battery  Replacement, Pry up the battery: 11 단계, 이미지 2개 중 2개
    • The battery is held in place by mild adhesive.
    • Insert the edge of an opening pick into the gap between the battery and the back cover assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use the opening pick to carefully pry up the battery and loosen the adhesive.
    댓글 쓰기
  12. SteelSeries Nimbus+ Controller Battery  Replacement, Remove the battery: 12 단계, 이미지 1개 중 1개
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Make sure to align the battery and the back cover of the controller correctly during reassembly.
    댓글 쓰기
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
Adriana Zwink
회원 가입일: 12/18/19
67,169 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 25,947개를 작성함
1가이드 댓글
Useless directions. The battery has 3 connectors. What is the mode? Where can you buy it? Polarity? If you have one with the right voltage and amps; but has two connectors what's do you do?
All this so-called repair guide says is: "This is how you open the case". Fantastic and then what???
Baldy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 47
전체 시간: 2,276
