주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Supersonic Matrix SC-91MID Back Cover Replacement
필요한 것
  1. Supersonic Matrix SC-91MID Back Cover Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • To begin, insert the plastic opening tool between the display and back cover and apply force until the back cover comes free from the device.
    댓글 쓰기
  2. Supersonic Matrix SC-91MID Back Cover Replacement: 2 단계, 이미지 3개 중 1개 Supersonic Matrix SC-91MID Back Cover Replacement: 2 단계, 이미지 3개 중 2개 Supersonic Matrix SC-91MID Back Cover Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Carefully remove orange ribbons from the motherboard by opening the small plastic flaps and pulling with tweezers.
    • This will disconnect the front part of the tablet from the back entirely. Set it safely aside and continue
    댓글 쓰기
  3. Supersonic Matrix SC-91MID Back Cover Replacement: 3 단계, 이미지 2개 중 1개 Supersonic Matrix SC-91MID Back Cover Replacement: 3 단계, 이미지 2개 중 2개
    • To remove the battery, use the plastic opening tool to pry one corner off of the battery and gently move the opening tool down to pull up one side of the battery.
    • The battery is glued down, so some force may be required to remove it from the back cover.
    댓글 쓰기
  4. Supersonic Matrix SC-91MID Back Cover Replacement: 4 단계, 이미지 2개 중 1개 Supersonic Matrix SC-91MID Back Cover Replacement: 4 단계, 이미지 2개 중 2개
    • To remove the speakers, use the plastic opening tool to gently pry the speaker from the back cover, then use the tweezers to remove them fully.
    댓글 쓰기
  5. Supersonic Matrix SC-91MID Back Cover Replacement: 5 단계, 이미지 3개 중 1개 Supersonic Matrix SC-91MID Back Cover Replacement: 5 단계, 이미지 3개 중 2개 Supersonic Matrix SC-91MID Back Cover Replacement: 5 단계, 이미지 3개 중 3개
    • To remove the motherboard, start by unscrewing the three (3) small Phillips head screws using a 1.5 mm Phillips head (Phillips #000) screwdriver.
    • The small red washers must be kept along with the screws when reassembling the device, make sure you store them safely until reassembling.
    • The motherboard has soldered connections to the battery, speakers, and the charging indicator LED. Be careful when pulling the motherboard from the back cover because these parts will come along with it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Michael Turner
회원 가입일: 03/31/18
121 평판
안내서 1개를 작성함
IUPUI, Team S1-G1, Wilson Spring 2018 IUPUI, Team S1-G1, Wilson Spring 2018 회원
IUPUI-WILSON-S18S1G1
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 457
