주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SwagTron T1 Wheel Replacement
필요한 것
    1. SwagTron T1 Wheel Replacement, Back Panels: 1 단계, 이미지 1개 중 1개
      • Ensure that the SwagTron is off.
      • Turn the SwagTron upside down to see the underside.
      댓글 쓰기
    2. SwagTron T1 Wheel Replacement: 2 단계, 이미지 3개 중 1개 SwagTron T1 Wheel Replacement: 2 단계, 이미지 3개 중 2개 SwagTron T1 Wheel Replacement: 2 단계, 이미지 3개 중 3개
      • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
      • The screws are tightly in place. It will take effort to screw them out.
      • The panel is still attached to the SwagTron by wires that go to the motherboard.
      • Carefully lift the panels off
      댓글 쓰기
    3. SwagTron T1 Wheel Replacement: 3 단계, 이미지 3개 중 1개 SwagTron T1 Wheel Replacement: 3 단계, 이미지 3개 중 2개 SwagTron T1 Wheel Replacement: 3 단계, 이미지 3개 중 3개
      • Follow the wires from the panels to the motherboard.
      • You may need to cut any zip ties that are holding the wires together.
      • There is one connection on the battery side and three on the other side that must be removed.
      • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
      • Your back panels are now completely removed.
      댓글 쓰기
    1. SwagTron T1 Wheel Replacement, Wheel: 4 단계, 이미지 3개 중 1개 SwagTron T1 Wheel Replacement, Wheel: 4 단계, 이미지 3개 중 2개 SwagTron T1 Wheel Replacement, Wheel: 4 단계, 이미지 3개 중 3개
      • Using your Phillips #2 screwdriver, remove the four 1cm screws that attach the gyroscope and its black case to the hoverboard.
      • Carefully remove this component and set it off to the side.
      댓글 쓰기
    2. SwagTron T1 Wheel Replacement: 5 단계, 이미지 3개 중 1개 SwagTron T1 Wheel Replacement: 5 단계, 이미지 3개 중 2개 SwagTron T1 Wheel Replacement: 5 단계, 이미지 3개 중 3개
      • Using your H 6.0 allen wrench, remove the four 20mm black bolts shown in the picture.
      • Take off the iron plate holding the wheel in place.
      • Remove the Motor/Wheel and set it aside close by to the hoverboard.
      • The wires from the Motor/Wheel should still be connected to the motherboard.
      • These bolts are very tight, it may be difficult to remove them. Try using a tool with a long handle.
      댓글 쓰기
    3. SwagTron T1 Wheel Replacement: 6 단계, 이미지 3개 중 1개 SwagTron T1 Wheel Replacement: 6 단계, 이미지 3개 중 2개 SwagTron T1 Wheel Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Slide the protective plastic off the connectors on the marked wires (green, blue, and yellow) using your hands or a set of tweezers.
      • The connectors on the wires of your hoverboard may be different from those shown in the pictures on the left due to differences in manufacturing.
      • Separate the set of marked green, blue, and yellow wires from their connectors.
      댓글 쓰기
    4. SwagTron T1 Wheel Replacement: 7 단계, 이미지 3개 중 1개 SwagTron T1 Wheel Replacement: 7 단계, 이미지 3개 중 2개 SwagTron T1 Wheel Replacement: 7 단계, 이미지 3개 중 3개
      • Finally separate the last connector shown on the left.
      • Your wheel is completely removed; slide in a new Motor/Wheel into the slot and follow the previous steps in reverse order.
      • Make sure the replacement wheel is snug. Neither rubbing on the outer rim nor on the side of the hoverboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Teagan Allen
회원 가입일: 04/18/17
432 평판
안내서 2개를 작성함
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G5
4 회원들
안내서 5개를 작성함
3가이드 댓글
Where do you get replacement wheels?
Elizabeth Schumacher - 답글 공유
Where can we find replacement wheels?
Liz Vance - 답글 공유
Mine won't stop beeping?? Fully charged.
Rachael Anderson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 44
전체 시간: 6,607
