주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Swagtron T3 Battery Replacement
필요한 것
    1. Swagtron T3 Battery Replacement, Cover: 1 단계, 이미지 2개 중 1개 Swagtron T3 Battery Replacement, Cover: 1 단계, 이미지 2개 중 2개
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      댓글 쓰기
    2. Swagtron T3 Battery Replacement: 2 단계, 이미지 3개 중 1개 Swagtron T3 Battery Replacement: 2 단계, 이미지 3개 중 2개 Swagtron T3 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      댓글 쓰기
    1. Swagtron T3 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • Unscrew the four 9.4 mm Phillips #1 machine screws attaching the battery to the base of the Swagtron T3.
      댓글 쓰기
    2. Swagtron T3 Battery Replacement: 4 단계, 이미지 2개 중 1개 Swagtron T3 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Detach the two cables connecting the battery to the Swagtron by pinching the connector clips and pulling the cables apart:
      • One red and black cable with a yellow connector.
      • One blue cable with a black connector.
      댓글 쓰기
    3. Swagtron T3 Battery Replacement: 5 단계, 이미지 2개 중 1개 Swagtron T3 Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the battery by pulling it out from under the cables.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Neeki Jarrami
회원 가입일: 04/10/17
197 평판
안내서 1개를 작성함
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 회원
CPSU-FORTE-S17S13G3
4 회원들
안내서 4개를 작성함
11가이드 댓글
where can i get a replacement battery?
rob - 답글 공유
Where can I get a replacement battery?
rob - 답글 공유
I can’t find a battery with the two wire harnesses coming out of the pack. Where can I order one?
Jeff Johnson - 답글 공유
Where Can I purchase a replacement batter for the T3
Leandre - June 18
Leandre Thornton - 답글 공유
Swagtron doesn’t sell the silver battery (even if you email them) I bought one from HoverboardRepair.com and it worked. Only difference is the small wire doesn’t come on the new battery but my hoverboard has worked just fine and I replaced the battery months ago.
Daniel Moravec - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 65
전체 시간: 8,979
