주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Swagtron T3 Gyroscope Replacement
필요한 것
    1. Swagtron T3 Gyroscope Replacement, Cover: 1 단계, 이미지 2개 중 1개 Swagtron T3 Gyroscope Replacement, Cover: 1 단계, 이미지 2개 중 2개
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      댓글 쓰기
    2. Swagtron T3 Gyroscope Replacement: 2 단계, 이미지 3개 중 1개 Swagtron T3 Gyroscope Replacement: 2 단계, 이미지 3개 중 2개 Swagtron T3 Gyroscope Replacement: 2 단계, 이미지 3개 중 3개
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      댓글 쓰기
    1. Swagtron T3 Gyroscope Replacement, Gyroscope: 3 단계, 이미지 1개 중 1개
      • The gyroscope is a blue rectangular circuit board on top of a white base and is closest to the wheel.
      • Detach the four cables connecting the gyroscope to the hoverboard by pinching the connector clips and pulling the cables out:
      • Three red and black cables with white connectors.
      • One multicolored cable with a black connector.
      댓글 쓰기
    2. Swagtron T3 Gyroscope Replacement: 4 단계, 이미지 1개 중 1개
      • Uncrew the four 7.2 mm Phillips #1 self-drilling screws connecting the blue gyroscope to the white plastic holding piece.
      댓글 쓰기
    3. Swagtron T3 Gyroscope Replacement: 5 단계, 이미지 2개 중 1개 Swagtron T3 Gyroscope Replacement: 5 단계, 이미지 2개 중 2개
      • Cut the plastic cable tie holding the cables together with utility scissors.
      • Disconnect the blue/green cable from the blue/white cable by pinching the connector clips and pulling the cables apart.
      댓글 쓰기
    4. Swagtron T3 Gyroscope Replacement: 6 단계, 이미지 1개 중 1개
      • Gently lift the blue gyroscope off of the white plastic holder piece.
      • After reassembling the Swagtron with the new gyroscope, check to make sure your Swagtron is balancing properly.
      • If it is still unbalanced, repeat all steps in this guide with the gyroscope by the other wheel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Emily Richter
회원 가입일: 04/10/17
351 평판
안내서 1개를 작성함
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 회원
CPSU-FORTE-S17S13G3
4 회원들
안내서 4개를 작성함
3가이드 댓글
Where can one buy the new gyroscope?
Mike - 답글 공유
Where is the best place to buy the gyroscope for the T3?
I see Ebay sells complete kits with motherboards and all.
Are they compatible?
Mike - 답글 공유
where can I buy new gyroscope
roccovalletta - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 38
전체 시간: 5,534
