주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Swagtron T3 Wheel Replacement
필요한 것
    1. Swagtron T3 Wheel Replacement, Cover: 1 단계, 이미지 2개 중 1개 Swagtron T3 Wheel Replacement, Cover: 1 단계, 이미지 2개 중 2개
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      댓글 쓰기
    2. Swagtron T3 Wheel Replacement: 2 단계, 이미지 3개 중 1개 Swagtron T3 Wheel Replacement: 2 단계, 이미지 3개 중 2개 Swagtron T3 Wheel Replacement: 2 단계, 이미지 3개 중 3개
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      댓글 쓰기
    1. Swagtron T3 Wheel Replacement, Wheel: 3 단계, 이미지 1개 중 1개
      • Unscrew the six 11.2 mm Phillips machine screws from the inside of the wheel.
      • You many need to spray a thin lubricant, such as PB Blaster, directly onto each of the six screw points to loosen them.
      댓글 쓰기
    2. Swagtron T3 Wheel Replacement: 4 단계, 이미지 2개 중 1개 Swagtron T3 Wheel Replacement: 4 단계, 이미지 2개 중 2개
      • Pull the wheel off of its base.
      • The wheel has a strong magnetic connection to the base, so separating the them will require a lot of force.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Klara Perkins
회원 가입일: 04/10/17
412 평판
안내서 2개를 작성함
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 회원
CPSU-FORTE-S17S13G3
4 회원들
안내서 4개를 작성함
3가이드 댓글
Hi,
my girl Swagtron T6 wheel is flat. Probably it is a nail hole. We are faraway from US, so I have to do it by myself. Can I get the wheel out for tire repairing?
Can you help me please?
Thanks
Susana Arzuaga - 답글 공유
Can't the wheel off
Christopher Primo - 답글 공유
I have a T6 Swagtron and I am struggling to get the wheel off. Are these magnets really that strong? It feels like there is something else holding the wheel in place. I tried prying it but doesn’t seem like its doing enough.
photostudiomilk - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 32
전체 시간: 4,724
