주요 콘텐츠로 건너뛰기
Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement
필요한 것
  1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: 1 단계, 이미지 1/3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: 1 단계, 이미지 2/3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: 1 단계, 이미지 3/3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 2 단계, 이미지 1/1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 3 단계, 이미지 1/1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: 4 단계, 이미지 1/3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: 4 단계, 이미지 2/3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: 4 단계, 이미지 3/3
    • Facing the inside of the front of the case, release the white ribbon cable by pulling the black rectangular connector at the end of the connection
    • Once the black holder is opened, gently pull the cable out of the holder.
  5. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 5 단계, 이미지 1/1
    • Facing the back of the small board, remove the two 2.0 mm Phillips #0 black screws that connect it to the back of the case.
  6. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 6 단계, 이미지 1/1
    • Carefully use a soldering iron to melt the solder in three places that connect the motion sensor. For more information on soldering follow this helpful guide.
    • Pull the sensor out from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Logan Sluder
회원 가입일: 09/18/19
544 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 38
전체 시간: 435
