주요 콘텐츠로 건너뛰기
Switch Pro Controller Case Replacement
필요한 것
  1. Switch Pro Controller Case Replacement, Remove the screws: 1 단계, 이미지 1개 중 1개
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
  2. Switch Pro Controller Case Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 1개 Switch Pro Controller Case Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 2개 Switch Pro Controller Case Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 3개
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Switch Pro Controller Case Replacement, Remove the screws: 3 단계, 이미지 1개 중 1개
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Switch Pro Controller Case Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 1개 Switch Pro Controller Case Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 2개 Switch Pro Controller Case Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 3개
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Switch Pro Controller Case Replacement, Remove the clear plastic cover: 5 단계, 이미지 1개 중 1개
    • Remove the clear plastic cover.
  6. Switch Pro Controller Case Replacement, Remove the battery: 6 단계, 이미지 3개 중 1개 Switch Pro Controller Case Replacement, Remove the battery: 6 단계, 이미지 3개 중 2개 Switch Pro Controller Case Replacement, Remove the battery: 6 단계, 이미지 3개 중 3개
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
  7. Switch Pro Controller Case Replacement, Remove the screws: 7 단계, 이미지 3개 중 1개 Switch Pro Controller Case Replacement, Remove the screws: 7 단계, 이미지 3개 중 2개 Switch Pro Controller Case Replacement, Remove the screws: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
  8. Switch Pro Controller Case Replacement: 8 단계, 이미지 3개 중 1개 Switch Pro Controller Case Replacement: 8 단계, 이미지 3개 중 2개 Switch Pro Controller Case Replacement: 8 단계, 이미지 3개 중 3개
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
  9. Switch Pro Controller Case Replacement, Open the flap: 9 단계, 이미지 2개 중 1개 Switch Pro Controller Case Replacement, Open the flap: 9 단계, 이미지 2개 중 2개
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
  10. Switch Pro Controller Case Replacement, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 1개 Switch Pro Controller Case Replacement, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
  11. Switch Pro Controller Case Replacement, Remove the front case: 11 단계, 이미지 1개 중 1개
    • Remove the front case.
결론
다른 22명이 해당 안내서를 완성하였습니다.
3가이드 댓글
I wondered why Xbox X controllers grips were difficult to remove and also make a squeak sound when the plastic part is not closing properly but a double-sided tape should do it...
Nicholin V - 답글
Disassembly was fine, but reassembly was a bit trickier. Removing the front casing from the chassis as in step 8 required a bit of force, since it seemed like the two were clipped together. Putting the two together, I can't seem to find where exactly that clipping connection was. I'd ignore it and move on to the screws, but it doesn't fit flush and I'm left with this narrow gap at the top that seems to be causing trouble. Any idea where I should be looking/applying pressure?
winter - 답글
At step eight, the easiest way to separate the two halves is to use your triangle pry tool, on the sides, underneath where the handle covers are, on both sides. I thought that I had missed a screw or something but that wasn't true. Just slowly pull them apart, I used this guide to clean my pro controller, thanks!
AvariceHW - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 80
지난 30일: 364
전체 시간: 26,656
