주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
T-Mobile Sparq SIM Card Replacement
필요한 것
  1. T-Mobile Sparq SIM Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
    • Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
    댓글 쓰기
  2. T-Mobile Sparq SIM Card Replacement: 2 단계, 이미지 1개 중 1개
    • Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
    • Insert the tip of your finger into the groove and gently lift the battery from the case.
    댓글 쓰기
  3. T-Mobile Sparq SIM Card Replacement, SIM Card: 3 단계, 이미지 1개 중 1개
    • Once the battery has been removed the SIM card is easily accessible. Press your finger gently on top of the exposed SIM card and slide it in the direction of the battery compartment until it comes out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
LeAnn Lewis
회원 가입일: 04/07/18
539 평판
안내서 4개를 작성함
IUPUI, Team S3-G3, Wilson Spring 2018 IUPUI, Team S3-G3, Wilson Spring 2018 회원
IUPUI-WILSON-S18S3G3
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 527
