주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TCL 30Z Screen Protector Replacement
필요한 것
    1. TCL 30Z Screen Protector Replacement, Prepare Your Workspace: 1 단계, 이미지 1개 중 1개
      • Begin by turning off your TCL 30Z and finding a clean, well-lit workspace. Gather all necessary tools and materials.
      댓글 쓰기
    2. TCL 30Z Screen Protector Replacement, Remove the Old Screen Protector: 2 단계, 이미지 1개 중 1개
      • Use a plastic pry tool to gently lift one corner of the existing screen protector. Gradually peel it off, applying slight pressure to release any adhesive. Note: Be careful not to damage the screen or any surrounding components during this process.
      댓글 쓰기
    3. TCL 30Z Screen Protector Replacement, Clean the Screen: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Microfiber Cleaning Cloths
      $3.99
      • Wipe the screen with a microfiber cloth to remove any smudges or fingerprints. Use cleaning solution or isopropyl alcohol for stubborn stains. Ensure the screen is completely dry before proceeding.
      • Reminder: Take your time during this step to ensure a clean surface for the new screen protector.
      댓글 쓰기
    4. TCL 30Z Screen Protector Replacement, Align the Replacement Screen Protector: 4 단계, 이미지 1개 중 1개
      • Carefully align the new screen protector with the edges of the screen. Once aligned, use your fingers to gently press it onto the screen.
      • Caution: Avoid touching the adhesive side of the screen protector to prevent fingerprints or debris.
      댓글 쓰기
    5. TCL 30Z Screen Protector Replacement, Smooth out Bubbles: 5 단계, 이미지 1개 중 1개
      • If any air bubbles are present, use a plastic pry tool or your fingers to smooth them toward the edges. Work from the center to ensure a bubble-free application.
      • Note: Small bubbles may disappear over time, but larger ones may need additional attention.
      댓글 쓰기
    6. TCL 30Z Screen Protector Replacement, Final Inspection: 6 단계, 이미지 1개 중 1개
      • Inspect the screen for any remaining bubbles or dust particles. If necessary, use dust removal stickers to lift and remove particles. Ensure the screen protector is securely in place.
      • Reminder: Allow the device to rest undisturbed for a few hours to ensure optimal adhesion.
      댓글 쓰기
결론
To replace the screen protector of TCL 30Z, follow these instructions in their order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Timothy
회원 가입일: 11/15/23
160 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 442
