주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TI-36X Pro Battery Replacement
필요한 것
    1. TI-36X Pro Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 TI-36X Pro Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
      • Remove the calculator's protective cover.
      • Place the calculator face down.
      댓글 쓰기
    2. TI-36X Pro Battery Replacement: 2 단계, 이미지 2개 중 1개 TI-36X Pro Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
      • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
      댓글 쓰기
    1. TI-36X Pro Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 TI-36X Pro Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
      • Remove the battery cover without disconnecting either end of the blue wire.
      • Use your finger to move the battery cover to the side.
      댓글 쓰기
    2. TI-36X Pro Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
      • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Robert Sekerak
회원 가입일: 04/25/14
664 평판
안내서 4개를 작성함
Cal Poly, Team 11-52, Amido Spring 2014 Cal Poly, Team 11-52, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G52
4 회원들
안내서 25개를 작성함
5가이드 댓글
Interesting that the cr2032 battery is not rechargeable, so is the solar panel real? Or does it bypass the battery and use the solar panel in lighted situations?
frogman896 - 답글 공유
The guide should specify that the CR2032 needs to be rechargeable. They are readily available at a popular online shopping website. I was skeptical that the solar was real too, because of the frosted plastic placed over it. Based on the pictures in this teardown, and another video showing a red LED in the solar circuit, I conclude that the solar charging circuit is real.
Jacob Ertel - 답글 공유
The manual doesn't specify a rechargeable battery. It just says a CR2032 Lithium battery. Unless all such batteries are rechargeable? I guess I'll find out since I just replaced the battery in mine and it's an Energizer CR2032, but it doesn't appear to say rechargeable anywhere on the packaging or the battery itself. I guess if it kills my calculator, it had a good run....
EDIT: The original battery that I took out of the calculator doesn't say rechargeable on it either.
Marc W - 답글 공유
good guide, I'd just like to add that in my case I needed to press the "Reset" button for my calculator to start up again
Greg B - 답글 공유
yeah but I have done that 3 times and now my calculator is officially announced dead....
Danielle Kennedy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 31
지난 30일: 151
전체 시간: 37,265
