주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TI-36X Pro Button Replacement
필요한 것
    1. TI-36X Pro Button Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 TI-36X Pro Button Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
      • Remove the calculator's protective cover.
      • Place the calculator face down.
      댓글 쓰기
    2. TI-36X Pro Button Replacement: 2 단계, 이미지 2개 중 1개 TI-36X Pro Button Replacement: 2 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
      • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
      댓글 쓰기
    1. TI-36X Pro Button Replacement, Battery: 3 단계, 이미지 2개 중 1개 TI-36X Pro Button Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
      • Remove the battery cover without disconnecting either end of the blue wire.
      • Use your finger to move the battery cover to the side.
      댓글 쓰기
    2. TI-36X Pro Button Replacement: 4 단계, 이미지 1개 중 1개
      • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
      • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
      댓글 쓰기
    1. TI-36X Pro Button Replacement, Button: 5 단계, 이미지 1개 중 1개
      • After removing the battery, use a Phillips #00 screwdriver to take out the 4.5mm screw directly to the right of the solar panel.
      • Do not disconnect any wires or you will need to solder them back on.
      댓글 쓰기
    2. TI-36X Pro Button Replacement: 6 단계, 이미지 1개 중 1개
      • Next, use a Phillips #00 screwdriver to remove the two screws located on each side of the striped ribbon between the two green circuit boards.
      댓글 쓰기
    3. TI-36X Pro Button Replacement: 7 단계, 이미지 1개 중 1개
      • Be careful not to scratch the gold lines on the circuit board since it may damage the circuit.
      • Carefully chisel off the 11 circular pieces that connect the lower circuit board to the calculator.
      • When reassembling the calculator, glue the lower circuit board back in place by dabbing glue into the holes that you chiseled.
      댓글 쓰기
    4. TI-36X Pro Button Replacement: 8 단계, 이미지 3개 중 1개 TI-36X Pro Button Replacement: 8 단계, 이미지 3개 중 2개 TI-36X Pro Button Replacement: 8 단계, 이미지 3개 중 3개
      • When removing the parts from the calculator be careful not to break any wires or ribbons. The solar panel, screen, and lower circuit board should remain connected throughout this guide.
      • Lift the top edge of the solar panel with a finger and slide it away from the circuit board to disconnect it from the calculator.
      • Carefully pry the screen out of the calculator with a prying tool or spudger.
      • Pry the lower circuit board from the calculator by inserting a prying tool between the base of the calculator and the circuit board.
      댓글 쓰기
    5. TI-36X Pro Button Replacement: 9 단계, 이미지 1개 중 1개
      • Grab one of the top corners of the gray rubber button pad and peel it off of the buttons.
      • If you turn the calculator over, all of the buttons will fall out.
      댓글 쓰기
    6. TI-36X Pro Button Replacement: 10 단계, 이미지 2개 중 1개 TI-36X Pro Button Replacement: 10 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Locate the button that needs replacement and lift it out of the calculator with tweezers.
      • If the buttons do fall out, use the second picture to put them back properly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Robert Sekerak
회원 가입일: 04/25/14
664 평판
안내서 4개를 작성함
Cal Poly, Team 11-52, Amido Spring 2014 Cal Poly, Team 11-52, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G52
4 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 44
전체 시간: 3,076
