주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TI-84 Plus Silver Edition Backup Battery Replacement
필요한 것
    1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: 1 단계, 이미지 3개 중 1개 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: 1 단계, 이미지 3개 중 2개 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: 1 단계, 이미지 3개 중 3개
      • Push firmly down on the tab located on the back of the calculator near the center.
      • Pull the tab up, lifting it off of the calculator and exposing the batteries.
      댓글 쓰기
    2. TI-84 Plus Silver Edition Backup Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
      • Push the positive (+) side of the batteries to remove them
      댓글 쓰기
    1. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: 3 단계, 이미지 1개 중 1개
      • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
      댓글 쓰기
    2. TI-84 Plus Silver Edition Backup Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Grab the plate and lift gently upward, to remove the backup battery cover.
      댓글 쓰기
    3. TI-84 Plus Silver Edition Backup Battery Replacement: 5 단계, 이미지 2개 중 1개 TI-84 Plus Silver Edition Backup Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
      • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
      • Push gently downward until the backup battery pops out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Agustin
회원 가입일: 10/20/13
1,047 평판
안내서 2개를 작성함
Cal Poly, Team 11-34, Amido Fall 2013 Cal Poly, Team 11-34, Amido Fall 2013 회원
CPSU-AMIDO-F13S11G34
4 회원들
안내서 20개를 작성함
9가이드 댓글
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - 답글 공유
Because it's a completely different calculator.
Ozan Munsuz - 답글 공유
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - 답글 공유
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - 답글 공유
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 64
지난 30일: 187
전체 시간: 72,138
