주요 콘텐츠로 건너뛰기
TOZO HT2 Battery Replacement
필요한 것
  1. TOZO HT2 Battery Replacement, Ear Pad: 1 단계, 이미지 3개 중 1개 TOZO HT2 Battery Replacement, Ear Pad: 1 단계, 이미지 3개 중 2개 TOZO HT2 Battery Replacement, Ear Pad: 1 단계, 이미지 3개 중 3개
    • Firmly hold the headphone housing in one hand to hold the device steady and put the other hand on the ear pad you intend to replace.
    • Note: Do not force the ear pad to come off or you risk breaking the tabs that keep the pads in place.
  2. TOZO HT2 Battery Replacement: 2 단계, 이미지 3개 중 1개 TOZO HT2 Battery Replacement: 2 단계, 이미지 3개 중 2개 TOZO HT2 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Twist the ear cover counterclockwise until it pops off.
    • Repeat for the other ear pad if necessary.
  3. TOZO HT2 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the four Phillips screws securing the speaker housing.
  4. TOZO HT2 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Use a spudger to gently pry the battery out of its housing.
    • Do not use a metal spudger as demonstrated in the photo. Take care not to puncture or bend the battery.
  5. TOZO HT2 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Take wire cutters and carefully snip the battery free, cutting as close to the battery as possible.
  6. TOZO HT2 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Solder the wires onto the new battery.
    • HANDLE WITH CARE: Soldering iron can be VERY hot (reaching temperatures up to or above 400°C or 800°F).
    • Wear eye protection while soldering and only do so in a well ventilated area and/or with a fume extractor.
    • Remove all possible fire hazards from the surrounding area.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
4다른 기여자 명과 함께
Raven M
회원 가입일: 08/28/24
614 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 48
전체 시간: 590
