주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tabby Kidz Battery Replacement
필요한 것
    1. Tabby Kidz Battery Replacement, Dismantling the tablet.: 1 단계, 이미지 2개 중 1개 Tabby Kidz Battery Replacement, Dismantling the tablet.: 1 단계, 이미지 2개 중 2개
      • First stick a thin metal wedge into the side of the tablet.
      • Now, pry the edge open gently in order to release the tabs around the device.
      댓글 쓰기
    2. Tabby Kidz Battery Replacement, Opening  the tablet.: 2 단계, 이미지 2개 중 1개 Tabby Kidz Battery Replacement, Opening  the tablet.: 2 단계, 이미지 2개 중 2개
      • Once you have half of the tabs undone, proceed to use your fingers to pull apart the two halves of the tablet.
      • Now, set the two pieces next to each other gently.
      • Make sure to be extremely gentle as you remove the two halves of the tablet. Otherwise, you may tear the speaker wires if you use excessive force.
      댓글 쓰기
    3. Tabby Kidz Battery Replacement, Removing the ground wire.: 3 단계, 이미지 2개 중 1개 Tabby Kidz Battery Replacement, Removing the ground wire.: 3 단계, 이미지 2개 중 2개
      • There is a small grey wire that runs from the green logic board to the battery. This is the ground wire, and it needs to be removed from the battery.
      • The orange end is much like tape so you can just peal it up and set it aside.
      댓글 쓰기
    4. Tabby Kidz Battery Replacement, De-soldering the battery.: 4 단계, 이미지 1개 중 1개
      • First, put on some safety glasses. Use extreme caution as this next step contains hazards, such as electric shock and burns.
      • Have your soldering gun heated up. Next, gently touch the silver colored bulbs at the end of the wires. Once the solder has melted, pull the wire off the green motherboard. Then, do the same to the other wire.
      댓글 쓰기
    5. Tabby Kidz Battery Replacement, Removing the battery.: 5 단계, 이미지 1개 중 1개
      • The old battery is attached to the back of the screen by adhesive double sided tape. This means you will have to peal the battery from the surface. A putty knife will be needed to get under the battery.
      • Do not worry if the battery bends a little.
      • When reattaching the new battery, use new 2mm double sided tape to stick the battery back on the screen.
      댓글 쓰기
    6. Tabby Kidz Battery Replacement, Disposing of the battery properly.: 6 단계, 이미지 1개 중 1개
      • The old battery needs to be recycled. Make sure of proper disposal.
      댓글 쓰기
    7. Tabby Kidz Battery Replacement, Congratulations!: 7 단계, 이미지 1개 중 1개
      • Now just follow the steps in reverse order in order to put your tablet back together.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mohamed
회원 가입일: 01/26/15
65 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 24
전체 시간: 611
