주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tagital T10 Battery Replacement
필요한 것
    1. Tagital T10 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Always make sure your device is completely powered off before performing repairs.
      • Remove the two 4 mm Phillips head screws at the top of the device.
      댓글 쓰기
    2. Tagital T10 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
      • Set the back cover aside.
      • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
      댓글 쓰기
    3. Tagital T10 Battery Replacement: 3 단계, 이미지 2개 중 1개 Tagital T10 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Locate the red and black wires that connect the battery to the motherboard.
      • Carefully peel away the tape that keeps the wires secured to the back of the display screen.
      댓글 쓰기
    4. Tagital T10 Battery Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Be sure to use tweezers when near the soldering iron because it is hot.
      • Soften the old solder by heating it with the soldering tool, so that the wires can be removed with tweezers.
      댓글 쓰기
    5. Tagital T10 Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Heat up the battery with the iOpener Heat tool in order to soften the adhesive that keeps the battery in place.
      • The iOpener Heat tool gets very hot, so be careful that you don't burn yourself.
      댓글 쓰기
    6. Tagital T10 Battery Replacement: 6 단계, 이미지 2개 중 1개 Tagital T10 Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the battery from the device with the plastic opening tool.
      • It may be difficult to remove so try reheating the iOpener and don't be afraid to use a good amount of force.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Cody D'Amato
회원 가입일: 09/26/16
303 평판
안내서 2개를 작성함
USF Tampa, Team 14-5, Eyestone Fall 2016 USF Tampa, Team 14-5, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G5
4 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 1,330
