주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tagital T10 Power button Replacement
필요한 것
    1. Tagital T10 Power button Replacement, Power button: 1 단계, 이미지 1개 중 1개
      • Always make sure your device is completely powered off before performing repairs.
      • Remove the two 4 mm Phillips head screws at the top of the tablet.
      댓글 쓰기
    2. Tagital T10 Power button Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
      • Set the back cover aside.
      • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Carefully set the back cover aside so that you do not rip the wires free.
      댓글 쓰기
    3. Tagital T10 Power button Replacement: 3 단계, 이미지 1개 중 1개
      • Remove all of the 4mm screws that attach the display screen to the back of the touch screen with brackets.
      • There should be a total of 8 screws and at size PH000.
      댓글 쓰기
    4. Tagital T10 Power button Replacement: 4 단계, 이미지 2개 중 1개 Tagital T10 Power button Replacement: 4 단계, 이미지 2개 중 2개
      • Remove all of the 4mm screws that attach the motherboard to the rest of the device.
      • One screw is located beneath the black tape that holds the rear-facing camera in place. Peel the tape up to access it.
      • There should be a total of 7 screws at size PH000.
      댓글 쓰기
    5. Tagital T10 Power button Replacement: 5 단계, 이미지 2개 중 1개 Tagital T10 Power button Replacement: 5 단계, 이미지 2개 중 2개
      • Locate the 2 ZIF connectors.
      • Flip up the black tab to release the two filaments, so that they are no longer connected to the motherboard.
      댓글 쓰기
    6. Tagital T10 Power button Replacement: 6 단계, 이미지 2개 중 1개 Tagital T10 Power button Replacement: 6 단계, 이미지 2개 중 2개
      • Locate the notification light on the upper corner of the device.
      • Gently pull on the wires to remove the light from it's housing.
      댓글 쓰기
    7. Tagital T10 Power button Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the motherboard from the back of the display screen.
      • Some wires are still attached to the device, so carefully set it to the side.
      댓글 쓰기
    8. Tagital T10 Power button Replacement: 8 단계, 이미지 2개 중 1개 Tagital T10 Power button Replacement: 8 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Push the power button towards the interior of the device to free it from its slot, using tweezers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Destin Dawsy
회원 가입일: 09/26/16
328 평판
안내서 2개를 작성함
USF Tampa, Team 14-5, Eyestone Fall 2016 USF Tampa, Team 14-5, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G5
4 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 32
전체 시간: 687
