주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Teenage Engineering OP-1 Battery Replacement
필요한 것
    1. Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: 1 단계, 이미지 3개 중 1개 Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: 1 단계, 이미지 3개 중 2개 Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: 1 단계, 이미지 3개 중 3개
      • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
      • Lift the back panel and remove it. The Connector Board is revealed.
      • Disconnect the flex connector by lifting it up with a spudger.
      댓글 쓰기
    1. Teenage Engineering OP-1 Battery Replacement, key removal: 2 단계, 이미지 3개 중 1개 Teenage Engineering OP-1 Battery Replacement, key removal: 2 단계, 이미지 3개 중 2개 Teenage Engineering OP-1 Battery Replacement, key removal: 2 단계, 이미지 3개 중 3개
      • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
      • The four longer keys from the fingerboard are to be handled from the left side to get them off.
      • The eight smaller keys need to be levered from the bottom up.
      댓글 쓰기
    2. Teenage Engineering OP-1 Battery Replacement, removing scissors mechanisms: 3 단계, 이미지 2개 중 1개 Teenage Engineering OP-1 Battery Replacement, removing scissors mechanisms: 3 단계, 이미지 2개 중 2개
      • The scissor mechanism of the eight small keys are obstructing the underlying screws.
      • By using again an opening tool or opening pick these can be snapped off easily.
      • When reassembling be sure to place them in with the correct side facing upwards.
      댓글 쓰기
    3. Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: 4 단계, 이미지 3개 중 1개 Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: 4 단계, 이미지 3개 중 2개 Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: 4 단계, 이미지 3개 중 3개
      • Loosen those 12 screws with a Phillips #00 screwdriver.
      • Then just pull off the four rotary knobs and the volume knob.
      • Now it is possible to slightly lift the keyboard and set it back.
      댓글 쓰기
    1. Teenage Engineering OP-1 Battery Replacement, battery removal: 5 단계, 이미지 3개 중 1개 Teenage Engineering OP-1 Battery Replacement, battery removal: 5 단계, 이미지 3개 중 2개 Teenage Engineering OP-1 Battery Replacement, battery removal: 5 단계, 이미지 3개 중 3개
      • Carefully pull out the connector cable from the connector board and bend it out of the way.
      • Disconnect the battery with a spudger. The connector needs to be lifted up and not being pulled to the side.
      • Now you can pry out the battery which is glued in with double sided adhesive tape.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
134,858 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,581개를 작성함
44가이드 댓글
This is great. What type of battery is the replacement?? thanks!
TrustNoShadows - 답글 공유
Hi, thanks for the question. I added another picture and put some information in the introduction.
Tobias Isakeit - 답글 공유
hey, thanks for this! is the battery plug simple JST or do I need to get something specific?
lfsaw - 답글 공유
Yes, a simple JST plug (probably type ACH)
Thanks for posting these instructions! I'm having trouble finding a battery that matches the one in the picture (unless I want to buy 1000 of them from Alibaba). Would this work?
http://www.ebay.com/itm/3-7V-1800mAh-Rec...
Dimensions are:
thick:3mm
wide:60mm
length:70mm
Clarke Robinson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 136
지난 30일: 513
전체 시간: 48,910
