주요 콘텐츠로 건너뛰기
Texas Instruments TI-30 XS Multiview Screen Replacement
필요한 것
  1. Texas Instruments TI-30 XS Multiview Screen Replacement, Open the device: 1 단계, 이미지 2개 중 1개 Texas Instruments TI-30 XS Multiview Screen Replacement, Open the device: 1 단계, 이미지 2개 중 2개
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger (or fingernail) to pry into the space between the blue back cover and the white body to take off the back cover.
  2. Texas Instruments TI-30 XS Multiview Screen Replacement, Open the battery compartiment: 2 단계, 이미지 1개 중 1개
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
  3. Texas Instruments TI-30 XS Multiview Screen Replacement, Eject the battery: 3 단계, 이미지 1개 중 1개
    • Use the spudger (or fingernail) to lift the battery from the black holder.
    • Put the new CR2032 battery in. Never insert a different type of battery!
    • Make sure the positive side of your CR2032 is facing up.
    • Reverse the steps 2 and 1.
  4. Texas Instruments TI-30 XS Multiview Screen Replacement, Free the screen: 5 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, carefully remove the two 3mm screws holding the screen in place.
  5. Texas Instruments TI-30 XS Multiview Screen Replacement, Carefully eject the screen: 6 단계, 이미지 1개 중 1개
    • Be sure to pull the ribbon cable, so that it only disconnects from the larger green board.
    • Gently lift the screen up from the front of the calculator, carefully disconnecting the ribbon cable from the larger green board.
  6. Texas Instruments TI-30 XS Multiview Screen Replacement, Finish up: 7 단계, 이미지 1개 중 1개
    • Once the screen has been removed, it should still have all connecting wires and the ribbon cable attached to it.
    • After the screen is replaced, you will have to re-solder the ribbon cable to the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Taylor Lamb
회원 가입일: 10/01/15
231 평판
안내서 1개를 작성함
Cal Poly, Team 11-2, Forte Fall 2015 Cal Poly, Team 11-2, Forte Fall 2015 회원
CPSU-FORTE-F15S11G2
4 회원들
안내서 9개를 작성함
4가이드 댓글
Where can you find a replacement screen for this calculator?
TJ
johns632 - 답글
Really the only way to find a replacement screen is by just buying some broken ones(but with a good screen) off of Ebay
kubagurPL -
dows soldering the ribbon cable back actually work?
kubagurPL - 답글
IMO this does not appear to be a repairable or serviceable part. Upon removal, the soldered or self-adhered conductors on the ribbon cable usually separate and tear off the ribbon cable, and are left stuck on the board. Unless you very very very very carefully scrape them off or they can be de-soldered, there's no replacing the display. The same problem will occur in reverse when trying to remove a good screen from a donor calculator, which is almost as expensive as the actual calculator (10-15$ USD). It's possible... just not sure it's worth it.
Rad Beltron - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 76
전체 시간: 5,446
