주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-30X IIS Battery Replacement
필요한 것
    1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: 1 단계, 이미지 3개 중 1개 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: 1 단계, 이미지 3개 중 2개 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: 1 단계, 이미지 3개 중 3개
      • Ensure that your calculator is a TI-30X IIS by looking in the top right corner of the front face.
      • Look at the rear face of the calculator and locate the four case screws. There are two at the top and two at the bottom.
      댓글 쓰기
    2. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: 2 단계, 이미지 2개 중 1개 Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: 2 단계, 이미지 2개 중 2개
      • Use a Philips 00 screwdriver to remove the four case screws on the rear face of the calculator.
      • Be sure to save the screws in a secure place as they are small and easy to lose. They will be needed later for reassembly.
      댓글 쓰기
    3. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: 3 단계, 이미지 3개 중 1개 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: 3 단계, 이미지 3개 중 2개 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: 3 단계, 이미지 3개 중 3개
      • With all four screws removed, use a flathead screwdriver or similar flat object to separate the front and rear casings.
      • There are six clips that keep the cases together. These areas will require extra force to separate, but use caution to not fracture the plastic pieces.
      댓글 쓰기
    4. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: 4 단계, 이미지 3개 중 1개 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: 4 단계, 이미지 3개 중 2개 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: 4 단계, 이미지 3개 중 3개
      • With the rear case off, the battery is exposed and accessible.
      • Using a pointed tool, slide the battery out of its terminal towards the near edge.
      • Once the battery is protruding from the contacts, remove it with your fingers.
      댓글 쓰기
    5. Texas Instruments TI-30X IIS Battery Replacement, Replacing Battery: 5 단계, 이미지 1개 중 1개
      • Properly dispose of the old battery.
      • Replace the battery with an identical one, positive terminal up and negative terminal facing down towards the circuit board.
      • Following the previous steps in the reverse order to reassemble the calculator.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Ryan
회원 가입일: 03/01/15
515 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 43
지난 30일: 174
전체 시간: 37,614
