주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-5130 Power Cord Replacement
필요한 것
    1. Texas Instruments TI-5130 Power Cord Replacement, Power Cord: 1 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement, Power Cord: 1 단계, 이미지 2개 중 2개
      • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
      댓글 쓰기
    2. Texas Instruments TI-5130 Power Cord Replacement: 2 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the top cover.
      • Gently pull up on the power cord to remove it from the back cover.
      댓글 쓰기
    3. Texas Instruments TI-5130 Power Cord Replacement: 3 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 3 단계, 이미지 2개 중 2개
      • This step is optional; however it makes it easier to work.
      • Using a PH1 screwdriver remove the two 10mm screws that hold down the transformer.
      • Gently remove the transformer.
      • Make sure that the calculator is not plugged in.
      댓글 쓰기
    4. Texas Instruments TI-5130 Power Cord Replacement: 4 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 4 단계, 이미지 2개 중 2개
      • Use a wire cutter to cut off the white cap and expose the wires. Try to cut close to the tip of the white cap - to leave as much wire as possible.
      • Note that there are 2 sets of wires connected to the power cord. Do each set of wires separately.
      댓글 쓰기
    5. Texas Instruments TI-5130 Power Cord Replacement: 5 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 5 단계, 이미지 2개 중 2개
      • Use a wire stripper to remove 1/2” of the protective covering on each of the wires.
      댓글 쓰기
    6. Texas Instruments TI-5130 Power Cord Replacement: 6 단계, 이미지 2개 중 1개 Texas Instruments TI-5130 Power Cord Replacement: 6 단계, 이미지 2개 중 2개
      • Twist the exposed section of the 2 wires together.
      • Twist a new cap over the exposed wires. Make sure that the cap covers all of the exposed wire.
      • Repeat steps 4-6 for the second set of wires.
      댓글 쓰기
    7. Texas Instruments TI-5130 Power Cord Replacement: 7 단계, 이미지 1개 중 1개
      • Replace the transformer and ensure that the new wire caps fit in the space shown.
      • Plug in the new power cord and test the calculator before replacing the top cover.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Shannon Perkins
회원 가입일: 09/17/15
652 평판
안내서 3개를 작성함
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 회원
USFSM-STEWART-F15S1G2
5 회원들
안내서 133개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 27
전체 시간: 877
