주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-80 Button Replacement
필요한 것
    1. Texas Instruments TI-80 Button Replacement, Batteries: 1 단계, 이미지 1개 중 1개
      • Locate battery cover on the back of the case.
      • Slide battery cover to the right reveal the batteries.
      댓글 쓰기
    2. Texas Instruments TI-80 Button Replacement: 2 단계, 이미지 1개 중 1개
      • Remove battery cover.
      • Slide the red lock down.
      • Slide the metal tab to the right of the top battery.
      • Remove the 3-Volt Lithium Coin Cell Battery.
      • Slide the red lock up.
      • Slide the metal tab to the right of the bottom battery.
      댓글 쓰기
    1. Texas Instruments TI-80 Button Replacement, Back Case: 3 단계, 이미지 3개 중 1개 Texas Instruments TI-80 Button Replacement, Back Case: 3 단계, 이미지 3개 중 2개 Texas Instruments TI-80 Button Replacement, Back Case: 3 단계, 이미지 3개 중 3개
      • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
      • Unscrew four 7.15 mm screws from back casing.
      • Using the blue plastic opener tool along the seam of the case, pry off front casing.
      • Start prying from the bottom of the calculator as the casing hooks into the top.
      댓글 쓰기
    1. Texas Instruments TI-80 Button Replacement, Motherboard and Screen: 4 단계, 이미지 2개 중 1개 Texas Instruments TI-80 Button Replacement, Motherboard and Screen: 4 단계, 이미지 2개 중 2개
      • Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
      • Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
      • Using the blue plastic opening tool, pry the Motherboard up.
      • Using the blue plastic opening tool, pry up the screen from the screen mount.
      댓글 쓰기
    1. Texas Instruments TI-80 Button Replacement, Check keyboard mat: 5 단계, 이미지 2개 중 1개 Texas Instruments TI-80 Button Replacement, Check keyboard mat: 5 단계, 이미지 2개 중 2개
      • Check the rubber mat for damage or obstruction at the location of non-functioning buttons.
      • Flip the mat over to assess dirt and damage.
      • Replace the mat if it is damaged.
      • Clean off the back of the Motherboard as necessary. The mat lies on top, so dirt and debris may build up. Repeat cleaning as needed.
      댓글 쓰기
    1. Texas Instruments TI-80 Button Replacement, Check Buttons: 6 단계, 이미지 1개 중 1개
      • Check the back of the buttons for damage or obstructions.
      • If obstructions are present, clear them.
      • Do not tilt the calculator, or buttons may fall out.
      댓글 쓰기
    2. Texas Instruments TI-80 Button Replacement, Replace Buttons: 7 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • If a button is damaged, use tweezers to lift the button out of the facing.
      댓글 쓰기
    3. Texas Instruments TI-80 Button Replacement, Insert new Buttons: 8 단계, 이미지 1개 중 1개
      • Insert new button, making sure that it is positioned properly.
      • For all buttons, there is an extrusion in the upper left quadrant when looking at the back of the key. These should be aligned with the top of the calculator.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
9다른 기여자 명과 함께
Calvin
회원 가입일: 01/08/15
201 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 24
전체 시간: 828
