주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-80 Keyboard Mat Replacement
필요한 것
    1. Texas Instruments TI-80 Keyboard Mat Replacement, Batteries: 1 단계, 이미지 1개 중 1개
      • Locate battery cover on the back of the case.
      • Slide battery cover to the right reveal the batteries.
      댓글 쓰기
    2. Texas Instruments TI-80 Keyboard Mat Replacement: 2 단계, 이미지 1개 중 1개
      • Remove battery cover.
      • Slide the red lock down.
      • Slide the metal tab to the right of the top battery.
      • Remove the 3-Volt Lithium Coin Cell Battery.
      • Slide the red lock up.
      • Slide the metal tab to the right of the bottom battery.
      댓글 쓰기
    1. Texas Instruments TI-80 Keyboard Mat Replacement, Back Case: 3 단계, 이미지 3개 중 1개 Texas Instruments TI-80 Keyboard Mat Replacement, Back Case: 3 단계, 이미지 3개 중 2개 Texas Instruments TI-80 Keyboard Mat Replacement, Back Case: 3 단계, 이미지 3개 중 3개
      • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
      • Unscrew four 7.15 mm screws from back casing.
      • Using the blue plastic opener tool along the seam of the case, pry off front casing.
      • Start prying from the bottom of the calculator as the casing hooks into the top.
      댓글 쓰기
    1. Texas Instruments TI-80 Keyboard Mat Replacement, Motherboard and Screen: 4 단계, 이미지 2개 중 1개 Texas Instruments TI-80 Keyboard Mat Replacement, Motherboard and Screen: 4 단계, 이미지 2개 중 2개
      • Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
      • Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
      • Using the blue plastic opening tool, pry the Motherboard up.
      • Using the blue plastic opening tool, pry up the screen from the screen mount.
      댓글 쓰기
    1. Texas Instruments TI-80 Keyboard Mat Replacement, Check keyboard mat: 5 단계, 이미지 2개 중 1개 Texas Instruments TI-80 Keyboard Mat Replacement, Check keyboard mat: 5 단계, 이미지 2개 중 2개
      • Check the rubber mat for damage or obstruction at the location of non-functioning buttons.
      • Flip the mat over to assess dirt and damage.
      • Replace the mat if it is damaged.
      • Clean off the back of the Motherboard as necessary. The mat lies on top, so dirt and debris may build up. Repeat cleaning as needed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
brian decater
회원 가입일: 01/13/15
301 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 32
전체 시간: 642
