주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-83 Plus Keyboard Mat Replacement
필요한 것
    1. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: 1 단계, 이미지 2개 중 1개 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Backup Battery: 1 단계, 이미지 2개 중 2개
      • Remove the battery cover.
      • Remove the AAA batteries from the calculator.
      댓글 쓰기
    2. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the 5mm Philips #00 screw holding backup battery cover.
      • Remove the backup battery cover.
      댓글 쓰기
    3. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 3 단계, 이미지 1개 중 1개
      • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
      • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
      댓글 쓰기
    1. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Back Case: 4 단계, 이미지 1개 중 1개
      • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
      댓글 쓰기
    2. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 5 단계, 이미지 2개 중 1개 Texas Instruments TI-83 Plus Keyboard Mat Replacement: 5 단계, 이미지 2개 중 2개
      • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
      댓글 쓰기
    1. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: 6 단계, 이미지 2개 중 1개 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Motherboard & Screen: 6 단계, 이미지 2개 중 2개
      • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
      • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
      댓글 쓰기
    2. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 7 단계, 이미지 2개 중 1개 Texas Instruments TI-83 Plus Keyboard Mat Replacement: 7 단계, 이미지 2개 중 2개
      • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
      댓글 쓰기
    1. Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: 8 단계, 이미지 2개 중 1개 Texas Instruments TI-83 Plus Keyboard Mat Replacement, Keyboard Mat: 8 단계, 이미지 2개 중 2개
      • Remove light gray rubber keyboard mat.
      • Keep your calculator face down to ensure the individual keys do not fall out.
      댓글 쓰기
    2. Texas Instruments TI-83 Plus Keyboard Mat Replacement: 9 단계, 이미지 1개 중 1개
      • Clean the contacts on the keyboard with a soft cloth.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
corey
회원 가입일: 10/02/12
11 평판
안내서 1개를 작성함
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 회원
CPSU-REGAN-F12S18G37
5 회원들
안내서 40개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 48
전체 시간: 5,204
