주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-83 Plus Motherboard & Screen Replacement
필요한 것
    1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: 1 단계, 이미지 2개 중 1개 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: 1 단계, 이미지 2개 중 2개
      • Remove the battery cover.
      • Remove the AAA batteries from the calculator.
      댓글 쓰기
    2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the 5mm Philips #00 screw holding backup battery cover.
      • Remove the backup battery cover.
      댓글 쓰기
    3. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
      • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
      댓글 쓰기
    1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Back Case: 4 단계, 이미지 1개 중 1개
      • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
      댓글 쓰기
    2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: 5 단계, 이미지 2개 중 1개 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
      댓글 쓰기
    1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: 6 단계, 이미지 2개 중 1개 Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: 6 단계, 이미지 2개 중 2개
      • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
      • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
      댓글 쓰기
    2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: 7 단계, 이미지 2개 중 1개 Texas Instruments TI-83 Plus Motherboard & Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kevin
회원 가입일: 10/02/12
479 평판
안내서 1개를 작성함
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 회원
CPSU-REGAN-F12S18G37
5 회원들
안내서 18개를 작성함
16가이드 댓글
Does anyone have any advice on acquiring replacement screens for the TI series? I was considering buying broken TIs on e-bay, but that may be unreliable.
Neil Cammardella - 답글 공유
Fixing TI83+'s is becoming addictive. Google Cemetech Forum on the net and see how he removes the screen from the Mother Board and solders wires permanently. I might add that he tests for resistance (ohms) first to determine if in fact that is where the problems exist. If I read between the lines, he tends to think that the screen/mother board ribbon cable is the primary culprit behind problems with the TI83's
shrinertom@yahoo.com
shrinertom - 답글 공유
My TI-83 Plus, the screen has turned Black, like to know where to send it to have it repaired e-mail address, (BagManOne@ecite.com)
Richard Brown - 답글 공유
Nothing is broken, the screen has turned Black, need to send it off and have it fixed, I can not do it my self because of the condition of my hands
It may not be broken. Try adjusting the screen contrast down.
Matthew Johnson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 104
전체 시간: 51,510
