주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-84 Plus CE Battery Replacement
필요한 것
    1. Texas Instruments TI-84 Plus CE Battery Replacement, TI-84 Plus CE Battery Repair: 1 단계, 이미지 1개 중 1개
      • Make sure your TI-84 Plus CE is off before starting the repair.
      • Any objects in your RAM will be removed if the battery is taken out. To ensure your objects are safe, archive them or back them up to a computer.
      댓글 쓰기
    2. Texas Instruments TI-84 Plus CE Battery Replacement, Battery door: 2 단계, 이미지 3개 중 1개 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door: 2 단계, 이미지 3개 중 2개 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door: 2 단계, 이미지 3개 중 3개
      • Locate the 2 Philips screws on the back of your calculator, as outlined.
      • These screws are not to be confused with the 6 Torx T6 scews surrounding the calculator.
      • With a Philips 0 or 00 screwdriver, unscrew the two screws.
      • The two Philips screws will not come out of the battery door, and will stay attached. Do not attempt to remove them completely.
      댓글 쓰기
    3. Texas Instruments TI-84 Plus CE Battery Replacement, Battery door lift: 3 단계, 이미지 3개 중 1개 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door lift: 3 단계, 이미지 3개 중 2개 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door lift: 3 단계, 이미지 3개 중 3개
      • Lift the battery door by grasping one of the two screws that are unscrewed, and pulling upwards.
      • Be sure to lift gently, as little force is needed to get the battery door removed.
      댓글 쓰기
    4. Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using your nails: 4 단계, 이미지 3개 중 1개 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using your nails: 4 단계, 이미지 3개 중 2개 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using your nails: 4 단계, 이미지 3개 중 3개
      • Pull out the battery using your nails, by inserting your nail into the small cut out, and lifting up on the battery.
      • As an alternative, you can use an opening tool. Go to Step 5 to see the procedure.
      댓글 쓰기
    5. Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using an opening tool: 5 단계, 이미지 3개 중 1개 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using an opening tool: 5 단계, 이미지 3개 중 2개 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using an opening tool: 5 단계, 이미지 3개 중 3개
      • Put your opening tool in the small opening as described in the photos.
      • Gently pull out the battery. You may need to hold your calculator to prevent your calculator from sliding around your working surface.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
o355
회원 가입일: 03/26/16
609 평판
안내서 1개를 작성함
8가이드 댓글
Where can I buy the replacement batteries?
louis liu - 답글 공유
Hey louis liu, I updated this guide with a link on where to buy the battery. It cost about $12 USD on Amazon: http://a.co/d/iTK2V0v
TheLastMillennial - 답글 공유
I replaced the battery and it worked for 1 week, the battery icon was on the screen which didn’t seem to get charged in full. After a week, the calc didn’t work anymore.
Lesly Simon - 답글 공유
So you're saying when you try charge the calculator it doesn't charge the battery at all? Does the LED next to the charging port turn solid orange when you plug it in? Have you tried a different power source (i.e. your computer or a wall block) or a different cable?
TI sells replacement batteries for $5
https://epsstore.ti.com/OA_HTML/ibeCCtpS...
Lisa Twitchell - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 105
지난 30일: 311
전체 시간: 59,121
