주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-92 Back Case Disassembly
필요한 것
    1. Texas Instruments TI-92 Back Case Disassembly, Back Cover: 1 단계, 이미지 3개 중 1개 Texas Instruments TI-92 Back Case Disassembly, Back Cover: 1 단계, 이미지 3개 중 2개 Texas Instruments TI-92 Back Case Disassembly, Back Cover: 1 단계, 이미지 3개 중 3개
      • The first step to any repair operation is to remove the front cover.
      • Grab the back of the calculator with one hand and the cover with the other.
      • Pull the cover off from one of the sides for easy removal.
      댓글 쓰기
    2. Texas Instruments TI-92 Back Case Disassembly: 2 단계, 이미지 2개 중 1개 Texas Instruments TI-92 Back Case Disassembly: 2 단계, 이미지 2개 중 2개
      • Orientate the calculator with the top facing towards you.
      • Slide the locking tab,found on the top part of the calculator, to the unlock position.
      댓글 쓰기
    3. Texas Instruments TI-92 Back Case Disassembly: 3 단계, 이미지 2개 중 1개 Texas Instruments TI-92 Back Case Disassembly: 3 단계, 이미지 2개 중 2개
      • "Locking Tab"
      • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
      • Then with the front of the calculator facing down, pull up on the back cover.
      • The calculator should now be orientated with the front facing down, as shown in picture 2.
      댓글 쓰기
    1. Texas Instruments TI-92 Back Case Disassembly, Batteries: 4 단계, 이미지 3개 중 1개 Texas Instruments TI-92 Back Case Disassembly, Batteries: 4 단계, 이미지 3개 중 2개 Texas Instruments TI-92 Back Case Disassembly, Batteries: 4 단계, 이미지 3개 중 3개
      • The Batteries are now exposed and the calculator is face down with the back towards you.
      • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
      • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
      • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
      • Now simply remove the battery.
      댓글 쓰기
    1. Texas Instruments TI-92 Back Case Disassembly, Texas Instruments TI-92 Back Case Disassembly: 5 단계, 이미지 3개 중 1개 Texas Instruments TI-92 Back Case Disassembly, Texas Instruments TI-92 Back Case Disassembly: 5 단계, 이미지 3개 중 2개 Texas Instruments TI-92 Back Case Disassembly, Texas Instruments TI-92 Back Case Disassembly: 5 단계, 이미지 3개 중 3개
      • Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
      댓글 쓰기
    2. Texas Instruments TI-92 Back Case Disassembly: 6 단계, 이미지 1개 중 1개
      • Unscrew the 19mm screw located near center of the back of the calculator.
      • Remove the panel being held by the screw.
      댓글 쓰기
    3. Texas Instruments TI-92 Back Case Disassembly: 7 단계, 이미지 1개 중 1개
      • Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
      댓글 쓰기
    4. Texas Instruments TI-92 Back Case Disassembly: 8 단계, 이미지 2개 중 1개 Texas Instruments TI-92 Back Case Disassembly: 8 단계, 이미지 2개 중 2개
      • Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
      • You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
      댓글 쓰기
    5. Texas Instruments TI-92 Back Case Disassembly: 9 단계, 이미지 2개 중 1개 Texas Instruments TI-92 Back Case Disassembly: 9 단계, 이미지 2개 중 2개
      • Pull out the rectangular module when it is finally loose enough.
      댓글 쓰기
    6. Texas Instruments TI-92 Back Case Disassembly: 10 단계, 이미지 2개 중 1개 Texas Instruments TI-92 Back Case Disassembly: 10 단계, 이미지 2개 중 2개
      • Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
      • Be careful not to tilt the front of the calculator at this point. The keyboard buttons are now unsupported and will fall out of place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Daniel Maldonado
회원 가입일: 04/14/10
264 평판
안내서 9개를 작성함
Cal Poly, Team 15-51, Garner Spring 2010 Cal Poly, Team 15-51, Garner Spring 2010 회원
CPSU-GARNER-S10S15G51
5 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 31
전체 시간: 2,738
