주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ThinkPad Edge E31 Hard Drive Replacement
필요한 것
  1. ThinkPad Edge E31 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    댓글 쓰기
  2. ThinkPad Edge E31 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    댓글 쓰기
  3. ThinkPad Edge E31 Hard Drive Replacement, ThinkPad Edge E31 Underside Disassembly: 3 단계, 이미지 1개 중 1개
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    댓글 쓰기
  4. ThinkPad Edge E31 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Remember to ground yourself before handing internal components of a laptop.
    • The hard drive is on the bottom left side of the exposed laptop.
    • Remove the 3.5mm long M3 screw securing the hard drive to the laptop.
    댓글 쓰기
  5. ThinkPad Edge E31 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 ThinkPad Edge E31 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • On the left edge of the hard drive there is a plastic tab. Pull up slightly on this tab.
    • Pull the tab to the left to remove the hard drive from the laptop.
    댓글 쓰기
  6. ThinkPad Edge E31 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • To remove the hard drive mounting bracket, locate the screws holding it on. There is one, 4mm long M2 screw on each of each on the long edges of the drive, and remove them. This will free the drive from the bracket. The bracket is needed to put the new drive back into the computer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Riley
회원 가입일: 03/19/17
601 평판
안내서 6개를 작성함
UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S6G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 606
