주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ThinkPad Edge E31 Wireless Card Replacement
필요한 것
  1. ThinkPad Edge E31 Wireless Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    댓글 쓰기
  2. ThinkPad Edge E31 Wireless Card Replacement: 2 단계, 이미지 1개 중 1개
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    댓글 쓰기
  3. ThinkPad Edge E31 Wireless Card Replacement, ThinkPad Edge E31 Underside Disassembly: 3 단계, 이미지 1개 중 1개
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    댓글 쓰기
  4. ThinkPad Edge E31 Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1개 중 1개
    • The wireless card is located above the Hard drive and RAM on the exposed laptop.
    • There are 2, 4mm long M2 screws holding the wireless card to the laptop. Unscrew the screws.
    댓글 쓰기
  5. ThinkPad Edge E31 Wireless Card Replacement: 5 단계, 이미지 1개 중 1개
    • Once the screws are removed, there will be 2 wires attached to the card. These can be easily popped off by hand to fully disconnect the card form the laptop.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Riley
회원 가입일: 03/19/17
601 평판
안내서 6개를 작성함
UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S6G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 361
