주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ThinkPad T420 Keyboard Replacement
필요한 것
      • 1.For access, remove these FRUs in order: Battery pack FRU. Memory slot cover FRU.
      • 2.Push down the keyboard a little and slide it toward the arrow 2 to detach the front edge of the keyboard from the frame.
      • 3.Lift the keyboard a little in the direction shown by arrow, and then detach the connector
      댓글 쓰기
    1. ThinkPad T420 Keyboard Replacement, Keyboard installation:: 2 단계, 이미지 1개 중 1개
      • 1.Attach the keyboard connector.
      • 2.Attach the keyboard so that the keyboard edges are under the frame as shown in this figure.
      • 3.To make sure that the front edge of the keyboard is housed firmly, gently press the keys with your palms and slightly slide the keyboard toward you until it snaps into position.
      • 4.Make sure that the front edge of the keyboard is attached firmly.
      • 5.Secure the keyboard by tightening the screws from the bottom side of the computer.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Laptop
회원 가입일: 05/29/18
1,029 평판
안내서 6개를 작성함
1가이드 댓글
I do not belive the first step has a picture. That would be very helpful. Thanks anyways.
Alexander Wiand - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 67
전체 시간: 3,688
