주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Thomas Kinkade Wonderland Express Disassembly
필요한 것
    1. Thomas Kinkade Wonderland Express Disassembly, Wonderland Express: 1 단계, 이미지 3개 중 1개 Thomas Kinkade Wonderland Express Disassembly, Wonderland Express: 1 단계, 이미지 3개 중 2개 Thomas Kinkade Wonderland Express Disassembly, Wonderland Express: 1 단계, 이미지 3개 중 3개
      • The very top part (cone) is glued to the next one below. It has to be carefully cut off or using a very little saw right above the tracks to get it off the part below. Disconnect the connector for the lights and unscrew the four nuts.
      댓글 쓰기
    2. Thomas Kinkade Wonderland Express Disassembly: 2 단계, 이미지 2개 중 1개 Thomas Kinkade Wonderland Express Disassembly: 2 단계, 이미지 2개 중 2개
      • Disconnect the connector for the lights and unscrew the four nuts. The plastic part holding the train and the gear can be removed. Work one level down after the other. After removing the nuts the levels are glued to the next base so the glue needs to be cut or removed as well.
      댓글 쓰기
    3. Thomas Kinkade Wonderland Express Disassembly: 3 단계, 이미지 1개 중 1개
      • View at the very base level with the motor on the left and the gearbox open.
      • Found the problem to be a stuck gearbox which prevented the trains from moving
      • Found problems on the PC board as well. Two transistors were overheated and not working any longer due to blocked gear box.
      댓글 쓰기
      • Assemble in reverse order
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Juergen Klute
회원 가입일: 02/02/14
733 평판
안내서 2개를 작성함
JKL Consulting JKL Consulting 회원
Business
1 회원
안내서 19개를 작성함
48가이드 댓글
I have the same Hawthorne Village tree and when purchased it played music with the lights & train in motion; it no longer plays the music when lit with trains in motion. I noticed no music playing on the video on this site. Looking to repair this problem.
Fred Lang - 답글 공유
My Christmas train tree does not run nor is there music nor is there lights you put batteries in and nothing happens. I need help repairing it or someplace to send it to have it repaired the Hawthorne company no longer wants to take responsibility for and yet they continue to sell it
queensgiftsamf - 답글 공유
If nothing at all happens once you put batteries in then I assume that there is a broken connection from batteries to the PC board. The other possible cause is that the PC board itself is the problem. In any case you need to dismantle the tree according to the description because the electronic board is at the very bottom. If you can, check the voltage and the transistors on the PC board.
Juergen Klute - 답글 공유
Hi,
Is there anyway to stop Santa from squeaking?
Thanks,
Noreen Snead
nmasnead@gmail.com
Noreen Snead - 답글 공유
I am trying to put the Santa and reindeer on the top of the tree. Could anyone help me with this assemble?
VALERIE BLOUNT - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 87
전체 시간: 23,206
