주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
해당 분해도는 수리 안내서가 아닙니다. Thomas Ride On Train 수리는 자사의 서비스 설명서를 사용하세요.
    1. Thomas Ride on Train - System Diagram and Components, Thomas Ride on Train - System Diagram and Components: 1 단계, 이미지 1개 중 1개
      • System Components
      • When power is applied to the charging connector it activates a relay which disconnects the power to the main circuits.
      • The main powerswitch is under the large yellow lever and simply applies power from the battery to the control board in the console.
      • A multipole switch is used to reverse the direction of the motor
      • An LED in the console flashes with the sound
      • The sound is provided by a loudspeaker in the base
      댓글 쓰기
    2. Thomas Ride on Train - System Diagram and Components: 2 단계, 이미지 2개 중 1개 Thomas Ride on Train - System Diagram and Components: 2 단계, 이미지 2개 중 2개
      • Charging Connector
      • The charging connector is on the rear of the train between the buffers
      • My connector is a "old style" connector which is effectively a phono, the new style is a more conventional power connector
      댓글 쓰기
    3. Thomas Ride on Train - System Diagram and Components: 3 단계, 이미지 1개 중 1개
      • Power Switch and Charging Relay Board
      댓글 쓰기
    4. Thomas Ride on Train - System Diagram and Components, 6v Sealed Lead Acid Battery: 4 단계, 이미지 1개 중 1개
      • This battery has been replaced, the originals attach via a clip
      • Note the fuse on the positive connector
      댓글 쓰기
    5. Thomas Ride on Train - System Diagram and Components, Reversing switch and LED: 5 단계, 이미지 1개 중 1개
      • This switch is controlled by the level on the console and switches the polarity of the motor connectors.
      • Middle position is off, the other two positions are forward and backwards
      • If you are replacing the LED don't forget that the polarity of the wires is important
      댓글 쓰기
    6. Thomas Ride on Train - System Diagram and Components, Control board: 6 단계, 이미지 1개 중 1개
      • Has three switches to activate the music and connectors leading off to the motor, speaker, LED and battery
      댓글 쓰기
    7. Thomas Ride on Train - System Diagram and Components, Loudspeaker: 7 단계, 이미지 1개 중 1개
      • This is a 16ohm speaker
      댓글 쓰기
    8. Thomas Ride on Train - System Diagram and Components, Motor: 8 단계, 이미지 1개 중 1개
      • 6v electric motor with capacitor for noise and spark suppressor wired across the terminals
      댓글 쓰기
작성자
2다른 기여자 명과 함께
Andy from Workshopshed
회원 가입일: 05/21/13
447 평판
안내서 3개를 작성함
10가이드 댓글
sound their but it's stoped moving
Leona - 답글 공유
If you've got sound but no movement then the most likely cause is the battery is discharged or defective. If you have a multimeter you could check the voltage on the battery.
If may also be a motor / mechanical issue. With the power disconnected you should be able to rotate the wheels but it won't spin freely as there is a gearbox.
Andy from Workshopshed - 답글 공유
Movement but no sound? Been charged
Shiipwreck Flynn - 답글 공유
That could be a problem with the sound board which lives inside the steering wheel. It's quite a challenge to get to that which is what caused me to write the guide in the first place. I had to clean the switches on that board to get mine to work.
Alternatively could be a loose or broken wire on the speaker which is down in the base, one of the first things you get too when stripping it down.
What do I clean it with? Just polish? Had a look. Wires look fine so im confused lol
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 19
지난 30일: 74
전체 시간: 9,066
