주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TomTom ONE Back Cover Replacement
필요한 것
    1. TomTom ONE Back Cover Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
      댓글 쓰기
    2. TomTom ONE Back Cover Replacement: 2 단계, 이미지 2개 중 1개 TomTom ONE Back Cover Replacement: 2 단계, 이미지 2개 중 2개
      • Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
      댓글 쓰기
    3. TomTom ONE Back Cover Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
      댓글 쓰기
    4. TomTom ONE Back Cover Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
      댓글 쓰기
    5. TomTom ONE Back Cover Replacement: 5 단계, 이미지 1개 중 1개
      • As you can see, the battery and the speaker are still attached to the device and must be removed.
      • Using the spudger, carefully pry out both the battery and the speaker.
      • When taking out the speaker, the entire plastic shock mounting casing will come out.
      • The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
      댓글 쓰기
    6. TomTom ONE Back Cover Replacement: 6 단계, 이미지 1개 중 1개
      • Once the battery and the speaker are removed, you now only have the back cover!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Trevor Foster
회원 가입일: 04/18/10
148 평판
안내서 3개를 작성함
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010 회원
CPSU-MANESS-S10S7G7
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 38
전체 시간: 7,486
