주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TomTom One XL Power Button Replacement
필요한 것
    1. TomTom One XL Power Button Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 TomTom One XL Power Button Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
      • Remove the 4 .4mm screws on the back of the device.
      댓글 쓰기
    2. TomTom One XL Power Button Replacement: 2 단계, 이미지 1개 중 1개
      • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
      • You can rotate TOMTOM XL to make prying back off easier.
      • Be careful not to injure the two wires connecting the pieces.
      댓글 쓰기
    3. TomTom One XL Power Button Replacement: 3 단계, 이미지 1개 중 1개
      • After prying both halves apart, they will be connected by two wires.
      • Carefully set the two halves next to each other making sure not to stress or damage the wires.
      댓글 쓰기
    4. TomTom One XL Power Button Replacement: 4 단계, 이미지 2개 중 1개 TomTom One XL Power Button Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
      • Be gentle while pulling the wires out, the plugs are easily injured.
      댓글 쓰기
    1. TomTom One XL Power Button Replacement, Power Button: 5 단계, 이미지 1개 중 1개
      • Using a Torx 6 screwdriver, remove the 4 .5mm screws connecting the motherboard to the screen assembly.
      • The motherboard is connected to the screen assembly via a ribbon wire. After removing the screws, be careful not to damage the wire or the port.
      댓글 쓰기
    2. TomTom One XL Power Button Replacement: 6 단계, 이미지 2개 중 1개 TomTom One XL Power Button Replacement: 6 단계, 이미지 2개 중 2개
      • Detach the ribbon wire from it's port on the back of the motherboard.
      댓글 쓰기
    3. TomTom One XL Power Button Replacement: 7 단계, 이미지 3개 중 1개 TomTom One XL Power Button Replacement: 7 단계, 이미지 3개 중 2개 TomTom One XL Power Button Replacement: 7 단계, 이미지 3개 중 3개
      • Now the power button is exposed and any obstructions can be easily removed.
      • If you want to replace the button it can easily be popped out using your hands.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jesse
회원 가입일: 03/11/15
101 평판
안내서 1개를 작성함
Colorado Springs, Team 9-6, Panko Spring 2015 Colorado Springs, Team 9-6, Panko Spring 2015 회원
UCCS-PANKO-S15S9G6
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 32
전체 시간: 2,614
