주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TomTom One XL Screen Replacement
필요한 것
    1. TomTom One XL Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 TomTom One XL Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
      • Remove the 4 .4mm screws on the back of the device.
      댓글 쓰기
    2. TomTom One XL Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
      • You can rotate TOMTOM XL to make prying back off easier.
      • Be careful not to injure the two wires connecting the pieces.
      댓글 쓰기
    3. TomTom One XL Screen Replacement: 3 단계, 이미지 1개 중 1개
      • After prying both halves apart, they will be connected by two wires.
      • Carefully set the two halves next to each other making sure not to stress or damage the wires.
      댓글 쓰기
    4. TomTom One XL Screen Replacement: 4 단계, 이미지 2개 중 1개 TomTom One XL Screen Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
      • Be gentle while pulling the wires out, the plugs are easily injured.
      댓글 쓰기
    1. TomTom One XL Screen Replacement, Screen: 5 단계, 이미지 2개 중 1개 TomTom One XL Screen Replacement, Screen: 5 단계, 이미지 2개 중 2개
      • Locate the 4 .4mm screws connecting the circuit board to the front panel.
      • Use the T6 Torx screwdriver and remove the four screws.
      댓글 쓰기
    2. TomTom One XL Screen Replacement: 6 단계, 이미지 3개 중 1개 TomTom One XL Screen Replacement: 6 단계, 이미지 3개 중 2개 TomTom One XL Screen Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Locate the ribbon cable connecting the front panel to the circuit board.
      • Locate the white tab locking the ribbon in place.
      • Using precision tweezers push the left and right side of the tab forward.
      • Gently pull the ribbon to disconnect the circuit board from the front panel.
      • If gently pulling on the ribbon doesn't release it then the tab hasn't been pushed far enough forward.
      댓글 쓰기
    3. TomTom One XL Screen Replacement: 7 단계, 이미지 3개 중 1개 TomTom One XL Screen Replacement: 7 단계, 이미지 3개 중 2개 TomTom One XL Screen Replacement: 7 단계, 이미지 3개 중 3개
      • Use the palate knife to pry the screen away from the front panel.
      • Pry between the light gray board and the black boarder of the TOMTOM XL screen.
      • Use moderate pressure when prying, slide the palate knife back and forth, and eventually the screen should pop out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
DeVhan
회원 가입일: 03/11/15
401 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 39
전체 시간: 1,279
