주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TomTom Runner Battery Replacement Guide
필요한 것
    1. TomTom Runner Battery  Replacement Guide, Wristband: 1 단계, 이미지 1개 중 1개
      • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
      댓글 쓰기
    2. TomTom Runner Battery  Replacement Guide: 2 단계, 이미지 2개 중 1개 TomTom Runner Battery  Replacement Guide: 2 단계, 이미지 2개 중 2개
      • Continue to lift up on the band until the screen of the watch becomes loose from the band.
      • You may need to apply a small amount of force downward on the face of the screen.
      • Continue to pull up on the wristband until it is completely off the watch.
      댓글 쓰기
    1. TomTom Runner Battery  Replacement Guide, Back Panel: 3 단계, 이미지 1개 중 1개
      • Grab the watch once it is separated from the wristband.
      댓글 쓰기
    2. TomTom Runner Battery  Replacement Guide: 4 단계, 이미지 1개 중 1개
      • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
      댓글 쓰기
    3. TomTom Runner Battery  Replacement Guide: 5 단계, 이미지 2개 중 1개 TomTom Runner Battery  Replacement Guide: 5 단계, 이미지 2개 중 2개
      • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
      • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
      • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
      댓글 쓰기
    4. TomTom Runner Battery  Replacement Guide: 6 단계, 이미지 2개 중 1개 TomTom Runner Battery  Replacement Guide: 6 단계, 이미지 2개 중 2개
      • Gently pull the back panel away from the front panel.
      • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
      댓글 쓰기
    5. TomTom Runner Battery  Replacement Guide: 7 단계, 이미지 2개 중 1개 TomTom Runner Battery  Replacement Guide: 7 단계, 이미지 2개 중 2개
      • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
      • Be gentle with the red and black wires. You do not want them to rip or pop out.
      • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
      댓글 쓰기
    1. TomTom Runner Battery  Replacement Guide, Battery: 8 단계, 이미지 3개 중 1개 TomTom Runner Battery  Replacement Guide, Battery: 8 단계, 이미지 3개 중 2개 TomTom Runner Battery  Replacement Guide, Battery: 8 단계, 이미지 3개 중 3개
      • Grab the back panel and a blue, plastic opening tool to pry the black battery pack off the back panel.
      • The battery pack is glued down, so it will be a bit sticky and harder to get off.
      • After removing the battery, you are ready to replace it with a new one.
      • If you need to replace the back panel, you are ready to take out the old battery and place it in the new back panel.
      댓글 쓰기
결론
This guide is complete when you have successfully removed the battery from the back panel. To reassemble your device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Amber Scarborough
회원 가입일: 03/20/17
1,157 평판
안내서 5개를 작성함
Texas Tech, Team S8-G6, Bennett Spring 2017 Texas Tech, Team S8-G6, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G6
4 회원들
안내서 21개를 작성함
30가이드 댓글
Ready to replace the battery. Would you happen to know where one can get a replacement battery?
Thanks
D.
Dan G - 답글 공유
where can you get a replacement battery for a tomtom watch 8rgo
john cash - 답글 공유
8gro battery where do I find one
Barend Fensham - 답글 공유
Very nice explaination. Would be good to mention the replacementbattery.
Very hard to find on the www.
Anyone found out already?
Know it’s lithium polymer with capacity of 190 mAh / 3,7V
When size is known, a replacement must be somewere.
Daan Ouwehand - 답글 공유
Can someone advise where we can purchase these batteries
sheldon Reddy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 96
전체 시간: 86,804
