주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TomTom Runner Front Cover Replacement
필요한 것
    1. TomTom Runner Front Cover  Replacement, Wristband: 1 단계, 이미지 1개 중 1개
      • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
      댓글 쓰기
    2. TomTom Runner Front Cover  Replacement: 2 단계, 이미지 2개 중 1개 TomTom Runner Front Cover  Replacement: 2 단계, 이미지 2개 중 2개
      • Continue to lift up on the band until the screen of the watch becomes loose from the band.
      • You may need to apply a small amount of force downward on the face of the screen.
      • Continue to pull up on the wristband until it is completely off the watch.
      댓글 쓰기
    1. TomTom Runner Front Cover  Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
      • Grab the watch once it is separated from the wristband.
      댓글 쓰기
    2. TomTom Runner Front Cover  Replacement: 4 단계, 이미지 1개 중 1개
      • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
      댓글 쓰기
    3. TomTom Runner Front Cover  Replacement: 5 단계, 이미지 2개 중 1개 TomTom Runner Front Cover  Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
      • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
      • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
      댓글 쓰기
    4. TomTom Runner Front Cover  Replacement: 6 단계, 이미지 2개 중 1개 TomTom Runner Front Cover  Replacement: 6 단계, 이미지 2개 중 2개
      • Gently pull the back panel away from the front panel.
      • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
      댓글 쓰기
    5. TomTom Runner Front Cover  Replacement: 7 단계, 이미지 2개 중 1개 TomTom Runner Front Cover  Replacement: 7 단계, 이미지 2개 중 2개
      • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
      • Be gentle with the red and black wires. You do not want them to rip or pop out.
      • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
      댓글 쓰기
    1. TomTom Runner Front Cover  Replacement, Front Cover: 8 단계, 이미지 2개 중 1개 TomTom Runner Front Cover  Replacement, Front Cover: 8 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Now lift the smaller square of copper off the Front Panel. Use the bent, metal precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
      • You will need to be gentle and pull the copper slowly so that it does not rip.
      댓글 쓰기
    2. TomTom Runner Front Cover  Replacement: 9 단계, 이미지 2개 중 1개 TomTom Runner Front Cover  Replacement: 9 단계, 이미지 2개 중 2개
      • Use the bent, metal precision tweezers to remove the thin copper piece from large square silver piece in the Front Casing.
      댓글 쓰기
    3. TomTom Runner Front Cover  Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the two 2.0 mm Torx Head screws with the T5 Torx screwdriver.
      댓글 쓰기
    4. TomTom Runner Front Cover  Replacement: 11 단계, 이미지 3개 중 1개 TomTom Runner Front Cover  Replacement: 11 단계, 이미지 3개 중 2개 TomTom Runner Front Cover  Replacement: 11 단계, 이미지 3개 중 3개
      • Use your fingers to gently pull the whole green motherboard out of the Front Casing.
      • If you have trouble using your fingers, then use the black Spudger tool.
      댓글 쓰기
결론
You are finished when all parts have been removed to leave just the front casing by itself. To reassemble your device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Amber Scarborough
회원 가입일: 03/20/17
1,157 평판
안내서 5개를 작성함
Texas Tech, Team S8-G6, Bennett Spring 2017 Texas Tech, Team S8-G6, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G6
4 회원들
안내서 21개를 작성함
9가이드 댓글
Great explaination, though you mention you don't replacement parts...? Can you share a link where you found the new front cover assembly?
steffen klifman - 답글 공유
Same question as Dyeffen : where can we get some replacement screens ?
Ansre
a_limal@yahoo.com.au
Andre - 답글 공유
Steffen sorry :-(
Andre - 답글 공유
Same question: where can we find the replacement cover part?
Thomas - 답글 공유
Hello if the control button is tight can the button be removed and cleaned underneath
Imran
Imran Moosagie - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 35
전체 시간: 6,894
