주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TomTom VIA 1530 TM Back Replacement
필요한 것
    1. TomTom VIA 1530 TM Back Replacement, Back: 1 단계, 이미지 2개 중 1개 TomTom VIA 1530 TM Back Replacement, Back: 1 단계, 이미지 2개 중 2개
      • Position the device so that the underside is facing up.
      • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
      • Firmly grab the EasyPort Mount and remove it.
      • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
      댓글 쓰기
    2. TomTom VIA 1530 TM Back Replacement: 2 단계, 이미지 2개 중 1개 TomTom VIA 1530 TM Back Replacement: 2 단계, 이미지 2개 중 2개
      • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
      • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
      댓글 쓰기
    3. TomTom VIA 1530 TM Back Replacement: 3 단계, 이미지 2개 중 1개 TomTom VIA 1530 TM Back Replacement: 3 단계, 이미지 2개 중 2개
      • Flip the device over so that the screen is facing up.
      • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
      • It may be easier to start at one of the corners.
      • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
      • This specific device's ribbon cable is torn.
      댓글 쓰기
    4. TomTom VIA 1530 TM Back Replacement: 4 단계, 이미지 2개 중 1개 TomTom VIA 1530 TM Back Replacement: 4 단계, 이미지 2개 중 2개
      • Carefully slide the screen forward, revealing the lower portion of the motherboard.
      • Remove the 3.6mm screw using the JIS #00 Screwdriver.
      • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
      댓글 쓰기
    5. TomTom VIA 1530 TM Back Replacement: 5 단계, 이미지 3개 중 1개 TomTom VIA 1530 TM Back Replacement: 5 단계, 이미지 3개 중 2개 TomTom VIA 1530 TM Back Replacement: 5 단계, 이미지 3개 중 3개
      • Disconnect the battery and speaker cables.
      • Unlatch the motherboard from the case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jennifer Zakaria
회원 가입일: 01/18/18
555 평판
안내서 6개를 작성함
Cal Poly, Team S12-G2, Banghart Winter 2018 Cal Poly, Team S12-G2, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G2
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 945
