주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Top Cover
필요한 것
  1. Top Cover, Remove screws: 1 단계, 이미지 1개 중 1개
    • Remove six Philips #2 screws from the bottom of the case.
    • REASSEMBLY CAUTION: To prevent thread stripping during reassembly, turn screws backwards slowly until you feel the screw thread drop into the original plastic thread, and only then, tighten screw normally but lightly - you're working with 20+ year-old plastics.
    댓글 쓰기
  2. Top Cover, Disconnect top cover ribbon cable: 2 단계, 이미지 1개 중 1개
    • Carefully fold the top and bottom open, revealing a ribbon cable connecting the two halves.
    • Unlock and disconnect the ribbon cable. Unlock by pulling the lock lever evenly on both sides, parallel to the board surface (not lift/pivot), in the direction of the ribbon cable.
    • When this ZIF (Zero Insertion Force) connector is properly unlocked, the ribbon cable should just fall right out of the socket (no need to pull with any strength).
    댓글 쓰기
  3. Top Cover, Remove RF shield: 3 단계, 이미지 2개 중 1개 Top Cover, Remove RF shield: 3 단계, 이미지 2개 중 2개
    • Simply lift the RF shield off the unit.
    • When reinstalling, take note of the 6 fork-like interlocking clips around the edge of the shield, which should engage with the original positions.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Matt Falcon
회원 가입일: 05/09/15
2,773 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 34
전체 시간: 258
