주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba Encore Mini Screen Replacement
필요한 것
    1. Toshiba Encore Mini Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Toshiba Encore Mini Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • To replace the battery, the rear cover must first be removed.
      • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
      • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
      댓글 쓰기
    2. Toshiba Encore Mini Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the rear cover and set it aside.
      댓글 쓰기
    3. Toshiba Encore Mini Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully remove the electrical tape that holds the battery in place.
      댓글 쓰기
    4. Toshiba Encore Mini Screen Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Encore Mini Screen Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
      댓글 쓰기
    5. Toshiba Encore Mini Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Gently lift the battery out of the device.
      • Be careful not to pull on the connecting wires.
      댓글 쓰기
    1. Toshiba Encore Mini Screen Replacement, Screen: 6 단계, 이미지 3개 중 1개 Toshiba Encore Mini Screen Replacement, Screen: 6 단계, 이미지 3개 중 2개 Toshiba Encore Mini Screen Replacement, Screen: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • The audio module must be removed to replace the screen.
      • Using needle-nose tweezers, carefully push the small white wire connector (red/black wires) out of its housing.
      • Gently remove red/black wire strands from the clips holding them to the back of the screen.
      댓글 쓰기
    2. Toshiba Encore Mini Screen Replacement: 7 단계, 이미지 2개 중 1개 Toshiba Encore Mini Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Gently pry audio module from the back of the screen using tweezers and spudger. Be careful not to pull on the wires.
      • Adhesive on the bottom of the speaker module may make it difficult to remove.
      • Set the audio module and attached wire aside.
      댓글 쓰기
    3. Toshiba Encore Mini Screen Replacement: 8 단계, 이미지 3개 중 1개 Toshiba Encore Mini Screen Replacement: 8 단계, 이미지 3개 중 2개 Toshiba Encore Mini Screen Replacement: 8 단계, 이미지 3개 중 3개
      • Using needle-nose tweezers, carefully flip up the dark gray cover on the right of the device holding the small orange/gold ribbon in place. (It is approximately 1/4" wide.)
      • With the tweezers, carefully pull the small ribbon out of its housing. It will stay attached to the device at the other end.
      댓글 쓰기
    4. Toshiba Encore Mini Screen Replacement: 9 단계, 이미지 2개 중 1개 Toshiba Encore Mini Screen Replacement: 9 단계, 이미지 2개 중 2개
      • A wide orange/gold ribbon connects the screen to the motherboard. (Ribbon is approximately 1" wide.)
      • Carefully pull the black tape off the ribbon housing and set it aside. You will need to replace the tape when reassembling the device.
      댓글 쓰기
    5. Toshiba Encore Mini Screen Replacement: 10 단계, 이미지 3개 중 1개 Toshiba Encore Mini Screen Replacement: 10 단계, 이미지 3개 중 2개 Toshiba Encore Mini Screen Replacement: 10 단계, 이미지 3개 중 3개
      • Damaging this ribbon will permanently disable your device!
      • Using needle-nose tweezers, carefully flip up the dark gray cover.
      • With the tweezers, carefully pull the wide ribbon from its housing. It will stay attached to the device at the other end.
      댓글 쓰기
    6. Toshiba Encore Mini Screen Replacement: 11 단계, 이미지 3개 중 1개 Toshiba Encore Mini Screen Replacement: 11 단계, 이미지 3개 중 2개 Toshiba Encore Mini Screen Replacement: 11 단계, 이미지 3개 중 3개
      • Using a Phillips 000 screwdriver, remove the screws holding components together.
      • Remove four 4.2 mm Phillips screws
      • Remove one 3 mm Phillips screw
      댓글 쓰기
    7. Toshiba Encore Mini Screen Replacement: 12 단계, 이미지 2개 중 1개 Toshiba Encore Mini Screen Replacement: 12 단계, 이미지 2개 중 2개
      • Holding the motherboard carefully by the edges, gently lift it up off the screen and carefully set it aside.
      • The motherboard may resist as you try to lift it --this is normal.
      댓글 쓰기
    8. Toshiba Encore Mini Screen Replacement: 13 단계, 이미지 1개 중 1개
      • Now that your screen is detached from the rest of the device components, it is ready to be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Christine co
회원 가입일: 07/09/15
131 평판
안내서 1개를 작성함
UW Tacoma, Team 1-3, Liner SU 2015 UW Tacoma, Team 1-3, Liner SU 2015 회원
UWT-LINER-SU15S1G3
4 회원들
안내서 6개를 작성함
1가이드 댓글
What is the small orange/gold ribbon in step 8 used for? I'm assuming that it's what registers touches on the screen because my tablet isn't reading my touches. I ask this because the dark grey bar on my tablet has been broken off, so there's nothing to hold the ribbon in place, and I can't do anything on my tablet because it won't respond to me touching it.
Gregory Banks - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 30
전체 시간: 1,815
